Microwave Oven door attenuation in dB?
3 replies · 2K views
NTL2009
I recently made a repair to the door switches/bracket on our microwave oven (MWO). All is well, but later, after reinstalling a trim piece and checking the fit, I noticed that with the door closed and latched, that there was a bit of play (1/8"?) - I could push the door a bit further closed, and it would spring back when I let go.
It probably was like this before and I just never noticed. But, I had some concern that it could be leaking. How to test this? My first step was a basic one, I took my phone, started a youtube video over WiFi (I made sure I was on the 2.4G WiFi band, which is close to the 2.45G MWO), turned the sound up, set it in the MWO, closed the door - and it kept playing.
If I opened the door and quickly looked at the WiFi antenna icon, it was at the lowest bar. Then I thought of a way to increase the information - I went into my router's admin page, and sure enough, it shows the signal strength of each wireless device. It indicated about -55 dBm with the door open, and about -88 dBm with the door closed. I had my wife push the door closed that last bit, and I maybe saw ~ 1 dB more attenuation. I repeated that with my tablet.
So I'm convinced the little bit of looseness on the door is no issue (it's probably acting as a wave-guide attenuator, rather than needing direct contact, and the length/width of any gap provides effective attenuation?). And with about 33 dB attenuation, a 1000 watt MWO would be below 1 watt total, in the range of a cell phone. So I think that is good, but the only specs I could find were rated in mW per cm^2.
Does 33dB attenuation seem right?
