Microwave tube mechanism of heating
The discussion focuses on the mechanisms by which microwave tubes heat materials, emphasizing the role of lossy conductors, dielectrics, and ceramics. It is established that materials such as ceramics can absorb microwave energy effectively, even when they appear dry on the surface. The dielectric heating process is explained as frictional, where the electric and magnetic fields of microwaves induce movement in polar molecules, such as water, leading to heat generation. Key insights include the importance of material properties, such as resistance and moisture content, in determining how effectively a substance absorbs microwave energy.
  • Understanding of microwave heating principles
  • Knowledge of dielectric materials and their properties
  • Familiarity with lossy conductors and their behavior in electromagnetic fields
  • Basic concepts of molecular polarity and charge separation
  • Research the properties of lossy dielectrics in microwave applications
  • Explore the design and manufacturing of microwave-safe ceramics
  • Study the effects of moisture content in ceramic materials on microwave absorption
  • Investigate the principles of dielectric heating and its applications in various materials
Engineers, material scientists, and anyone involved in the design of microwave heating systems or materials that interact with microwaves will benefit from this discussion.
Vrbic
Hello,
first of all, I understand, how microwave tube works but I'm interesting in how exactly the microwave heat up a things? What's the matter inside. I have heard about increasing energy of molecules of water by polarization them by micro-wave. But I have got a plate which is not from glass and it is heated up more than things on it. I suppose it is not from water :)
My idea is that lattice parameter "a" of that material has resonance length for micro-waves. Or frequency of these waves is resonance frequency for such lattice. Or where is true?
Science news on Phys.org
All that is necessary for a material to be heated is that it be a conductor which is not ideal, but lossy, i.e. has some resistance. It could also be a lossy dielectric or a lossy magnetic material; both of these have characteristic curves that show some hysteresis. All such materials absorb some energy from the microwaves. For example, most foods are lossy conductors. The microwave field induces currents in those materials and the I squared R loss produces heat.
no, this isn't correct
ceramics in general are very good at absorbing microwave energy. and if there is still any moisture within the ceramic.
Then those water molecules will get warm in the same way as water molecules in the food via the absorbed energy
There are various ceramics that manufactured for their energy absorption without getting too hot to touch
these are available for use in microwave ovens. Also consider the ceramics that were used in the space shuttle heat protection tiles,
these tiles could be glowing red but you could still pick them up by handDave
The dielectric heating process caused by microwave absorption is basically frictional - the electric and magnetic field vectors of the microwaves cause separated charge to move, so any molecules with a degree of charge separation (including any polar molecules such as water) will move in response to the incident microwaves and this will cause bulk heating of the material.
So if I understand "classical" heating up of water: It is caused by ROTATING or MOVING of charged particles? My idea is that dipole molecules of water just turn round because of changing of electromangnetic field by microwave. Is it true?
Absorbed energy seems very general :) How exactly? Is it by rotating of dipol moleculs of water because of microwave (electromagnetic field)?
Do you want to say that in ceramics are moleculs of water or that moleculs of ceramics behave similary as water? My plate was definitely dry (on surface).
yes, but you don't know how dry the ceramic is inside. Standard kiln fired ceramics can still have small quantities of water in it
ceramics produced specifically for microwave oven use are more carefully produced
  • · Replies 66 ·
  • · Replies 60 ·
13K
