Kaura
- 122
- 22
Hello, I am currently working on a version of Minesweeper that uses Java.
Currently the code seems to work relatively well and the game runs properly, however there is an issue.
I currently have the set to update the board on every mouse click and release, as these are currently the only actions that can trigger a change in the board. I have not implemented a timer yet. The board updates correctly but it flickers, flashing white for a moment and then quickly drawing the objects on the board like the tiles.
I believe that this is due to me using a loop in the paint method to individually draw each tile based on its given characteristics. I do not know if this is simply too much for the system to handle when trying to drawing instantaneously or if there is some other underlying issue.
I have searched the web and I think that implementing double buffering or what not might solve the issue but I am not exactly sure how to do that.
Here is the code, any advice is much appreciated.
Java:
import javax.swing.JFrame;
import javax.swing.SwingUtilities;
import java.awt.Font;
import java.awt.Color;
import java.awt.Graphics;
import java.awt.event.MouseEvent;
import java.awt.event.MouseListener;
import java.util.Scanner;
* Minesweeper
* @author Kaura
public class Minesweeper {
* Tile
public static class Tile {
private boolean bomb = false;
private boolean marked = false;
private boolean covered = true;
private int number = 0;
public boolean checkBomb() {return bomb;}
public boolean checkMarked() {return marked;}
public boolean checkCovered() {return covered;}
public int getNumber() {return number;}
public void setBomb() {bomb = true;}
public void mark() {marked = !marked;}
public void uncover() {covered = false;}
public void setNumber(int number) {this.number = number;}
* Board
public static class Board {
private int width;
private int height;
private int difficulty;
private int bombs;
private int covered;
private int marked;
private int deadX;
private int deadY;
private long time;
private boolean running;
private boolean winner;
private Tile[][] tiles;
public Board(int width, int height, int bombs) {
this.width = width;
this.height = height;
this.bombs = bombs;
this.covered = width*height;
this.marked = 0;
this.deadX = -1;
this.deadY = -1;
this.time = System.currentTimeMillis();
this.running = true;
this.winner = false;
//Create Tiles//
tiles = new Tile[width][height];
for(int k = 0; k < width; k++) {
for(int f = 0; f < height; f++) {
tiles[k][f] = new Tile();
//Set Bombs//
for(int k = 0; k < bombs; k++) {
int x = (int)Math.floor(Math.random()*width);
int y = (int)Math.floor(Math.random()*height);
if(!tiles[x][y].checkBomb()) {
tiles[x][y].setBomb();
} else {
k--;
//Set Numbers//
int total = 0;
if(k > 0 && f > 0 && tiles[k-1][f-1].checkBomb()) total++;
if(f > 0 && tiles[k][f-1].checkBomb()) total++;
if(k < width-1 && f > 0 && tiles[k+1][f-1].checkBomb()) total++;
if(k > 0 && tiles[k-1][f].checkBomb()) total++;
if(k < width-1 && tiles[k+1][f].checkBomb()) total++;
if(k > 0 && f < height-1 && tiles[k-1][f+1].checkBomb()) total++;
if(f < height-1 && tiles[k][f+1].checkBomb()) total++;
if(k < width-1 && f < height-1 && tiles[k+1][f+1].checkBomb()) total++;
tiles[k][f].setNumber(total);
//Uncover a Tile//
public void uncoverTile(int x, int y) {
covered--;
tiles[x][y].uncover();
if(tiles[x][y].checkMarked()) markTile(x, y);
if(tiles[x][y].checkBomb()) {
deadX = x;
deadY = y;
gameover();
return;
} else if(tiles[x][y].getNumber() == 0) {
for(int k = (x==0?0:-1); k <= (x<width-1?1:0); k++) {
for(int f = (y==0?0:-1); f <= (y<height-1?1:0); f++) {
if(tiles[k+x][f+y].checkCovered()) {
uncoverTile((k+x), (f+y));
} if(covered <= bombs) {
winner = true;
gameover();
//Mark Tile//
public void markTile(int x, int y) {
if(!tiles[x][y].checkCovered()) return;
tiles[x][y].mark();
marked += (tiles[x][y].checkMarked())?1:-1;
//Uncover Bombs//
public void reveal() {
for(int k = 0; k < this.width; k++) {
for(int f = 0; f < this.height; f++) {
if(tiles[k][f].checkBomb()) tiles[k][f].uncover();
//Game Over//
public void gameover() {
running = false;
if(!winner) reveal();
System.out.print("Game Over: ");
System.out.println((winner)?"You Win":"You Lose");
//Timer//
public int getTime() {
return (int)(System.currentTimeMillis()-time)/1000;
//Access//
public int getWidth() {return this.width;}
public int getHeight() {return this.height;}
public int getBombs() {return this.bombs;}
public int getCovered() {return this.covered;}
public int getMarked() {return this.marked;}
public int getDeadX() {return this.deadX;}
public int getDeadY() {return this.deadY;}
public boolean checkRunning() {return this.running;}
public Tile getTile(int x, int y) {return this.tiles[x][y];}
* Screen
public static class Screen extends JFrame implements MouseListener {
private static final long serialVersionUID = 1L;
private final int WIDTH = 960;
private final int HEIGHT = 960;
private final int TILE = 40;
private final Font font = new Font("Terminal", Font.BOLD, 30);
private final Color BG = Color.decode("#black");
private final Color FG = Color.decode("#f0f0f0");
private final Color GD = Color.decode("#c0c0c0");
private final Color HL1 = Color.decode("#f8f8f8");
private final Color HL2 = Color.decode("#c0c0c0");
private final Color F1 = Color.decode("#000000");
private final Color F2 = Color.decode("#ff0000");
private final Color BM = Color.decode("#000000");
private final Color EX = Color.decode("#ff0000");
private final Color[] color = {
Color.decode("#f0f0f0"),
Color.decode("#0100fe"),
Color.decode("#017f01"),
Color.decode("#fe0000"),
Color.decode("#010080"),
Color.decode("#810102"),
Color.decode("#008081"),
Color.decode("#000000"),
Color.decode("#808080"),
private int boardX, boardY;
private int boardWidth, boardHeight;
private Board board;
//Constructor//
public Screen() {
addMouseListener(this);
setTitle("Minesweeper");
setSize(WIDTH, HEIGHT);
setResizable(false);
setVisible(true);
setDefaultCloseOperation(EXIT_ON_CLOSE);
newgame();
//New Game//
private void newgame() {
board = new Board(20, 15, 25);
boardX = WIDTH/2-board.getWidth()*TILE/2;
boardY = HEIGHT/2-board.getHeight()*TILE/2;
boardWidth = board.getWidth()*TILE;
boardHeight = board.getHeight()*TILE;
//Painter//
public void paint(Graphics canvas) {
canvas.clearRect(0, 0, WIDTH, HEIGHT);
canvas.setColor(BG);
canvas.fillRect(0, 0, WIDTH, HEIGHT);
canvas.setColor(HL2);
canvas.fillPolygon(
new int[] {boardX-6, boardX+boardWidth+6, boardX-6},
new int[] {boardY-6, boardY-6, boardY+boardHeight+6}, 3
canvas.setColor(HL1);
canvas.fillPolygon(
new int[] {boardX+boardWidth+6, boardX-6, boardX+boardWidth+6},
new int[] {boardY+boardHeight+6, boardY+boardHeight+6, boardY-6}, 3
canvas.setColor(FG);
canvas.fillRect(boardX, boardY, boardWidth, boardHeight);
canvas.setColor(GD);
for(int k = 0; k < board.getWidth(); k++) {
canvas.drawLine(boardX+k*TILE, boardY, boardX+k*TILE, boardY+boardHeight);
} for(int k = 0; k < board.getHeight(); k++) {
canvas.drawLine(boardX, boardY+k*TILE, boardX+boardWidth, boardY+k*TILE);
//Fill Board//
for(int f = 0; f < board.getHeight(); f++) {
//Base//
if(board.getTile(k, f).checkBomb()) {
if(k == board.getDeadX() && f == board.getDeadY()) {
canvas.setColor(EX);
canvas.fillRect(boardX+k*TILE, boardY+f*TILE, TILE, TILE);
canvas.setColor(BM);
canvas.fillOval(boardX+k*TILE+TILE/2-9, boardY+f*TILE+TILE/2-9, 20, 20);
canvas.fillOval(boardX+k*TILE+TILE/2-5, boardY+f*TILE+TILE/2-5, 6, 6);
} else {
canvas.setFont(font);
canvas.setColor(color[board.getTile(k, f).getNumber()]);
canvas.drawString(board.getTile(k, f).getNumber()+"", boardX+k*TILE+TILE/2-7, boardY+f*TILE+TILE/2+12);
//Covered
if(board.getTile(k, f).checkCovered()) {
canvas.fillPolygon(
new int[] {boardX+k*TILE, boardX+k*TILE+TILE, boardX+k*TILE},
new int[] {boardY+f*TILE, boardY+f*TILE, boardY+f*TILE+TILE}, 3
canvas.fillPolygon(
new int[] {boardX+k*TILE, boardX+k*TILE+TILE, boardX+k*TILE+TILE},
new int[] {boardY+f*TILE+TILE, boardY+f*TILE+TILE, boardY+f*TILE}, 3
canvas.fillRect(boardX+k*TILE+5, boardY+f*TILE+5, 30, 30);
//Marked//
if(board.getTile(k, f).checkMarked()) {
canvas.setColor(F1);
canvas.fillPolygon(
new int[] {
boardX+k*TILE+10, boardX+k*TILE+10,
boardX+k*TILE+19, boardX+k*TILE+19,
boardX+k*TILE+21, boardX+k*TILE+21,
boardX+k*TILE+30, boardX+k*TILE+30
new int[] {
boardY+f*TILE+32, boardY+f*TILE+26,
boardY+f*TILE+24, boardY+f*TILE+8,
boardY+f*TILE+8, boardY+f*TILE+24,
boardY+f*TILE+26, boardY+f*TILE+32
}, 8
canvas.setColor(F2);
canvas.fillPolygon(
new int[] {boardX+k*TILE+21, boardX+k*TILE+10, boardX+k*TILE+10, boardX+k*TILE+21},
new int[] {boardY+f*TILE+6, boardY+f*TILE+12, boardY+f*TILE+14, boardY+f*TILE+20}, 4
//Mouse Events//
private int pressX, pressY, releaseX, releaseY;
public void mouseClicked(MouseEvent e) {return;}
public void mouseEntered(MouseEvent e) {return;}
public void mouseExited(MouseEvent e) {return;}
public void mousePressed(MouseEvent e) {
if(board.checkRunning()) {
pressX = e.getX();
pressY = e.getY();
int tileX = (pressX-boardX)/TILE;
int tileY = (pressY-boardY)/TILE;
} repaint();
public void mouseReleased(MouseEvent e) {
releaseX = e.getX();
releaseY = e.getY();
int tileX = (releaseX-boardX)/TILE;
int tileY = (releaseY-boardY)/TILE;
if(tileX != (pressX-boardX)/TILE || tileY != (pressY-boardY)/TILE) return;
if((tileX<0||tileX>board.getWidth())||(tileY<0||tileY>board.getHeight())) return;
//System.out.println(tileX+", "+tileY);
Tile tile = board.getTile(tileX, tileY);
if(SwingUtilities.isLeftMouseButton(e)) {
if(!tile.checkMarked()) {
if(tile.checkCovered()) {
board.uncoverTile(tileX, tileY);
} else if(SwingUtilities.isRightMouseButton(e)) {
board.markTile(tileX, tileY);
} repaint();
* Main Method
public static void main(String[] args) {
Screen game = new Screen();
