Minimum force required to form sphere
36 replies · 4K views
Tanya Sharma
Doing a vertical force balance 2Fcosθ=mg ,where m is the mass of water .
Not sure how to proceed .
What role does the pin hole at the top play ?
I would be grateful if somebody could help me with the problem.
... that is the key question.
Think about it - what does putting a pinhole in the top do that not having a hole there not do?
i.e. imagine there is also a pinhole at the bottom - what difference would a hole at the top make?
Pace Simon, but the pinhole at the top is only to get around a complication that the setter did not want to get tangled up with. It looks like you didn't notice the complication anyway, so what you have done so far is ok. But you need another equation. The answer to the question should be an actual number, not dependent on any variables.
I have thought about it . Please elaborate .
Chet ,
I somehow feel there is a simpler , less mathematically rigorous solution to this problem .
Is the force across the interface between the spheres given by $$2 ρg\int_0^R \sqrt{R^2 - (R-h)^2}h dh$$ ? But then ρ comes in picture and the integral also doesn't look nice .
The integrand looks good. Check the limits.
If you want to avoid the integration, consider a vertically oriented circular area submerged in a static fluid. Consider two, symmetrically placed horizontal strips of area as shown in blue. How do the pressures at each of these strips compare to the pressure at z = 0? Does the sum of the forces on the two strips simplify?
TSny said:
The integrand looks good. But your limits don't seem right.
It should be from 0 to 2R . Right?
Yes .
If we denote the pressure at z=0 to be P ,pressure at the upper blue strip is P-ρgz . Pressure at the lower blue strip is P+ρgz
2P . Is that so ?
Edit : 2P is sum of pressures .
Yes.
Yes.
2P . Is that so ?
This is the total force on the two strips?
Total force on two strips is 4P##\sqrt{R^2-z^2}dz## .
Total force on vertically oriented circular area should be ## \pi ρgR^3 ## . Is that correct ?
Tanya Sharma said:
Total force on the circular strip should be ## \pi ρgR^3 ## . Is that correct ?
Should atmospheric pressure be included?
It should be ##(P_{atm}+ρgR)πR^2## ?
Yes, the total force on the circle is the pressure at the center times the total area of the circle. Do you see why they put the little hole at the top?
What should be the next step ?
The next step should probably be to take a break and sleep on it. (Isn't it late there?)
Anyway, one thing to think about is how your result for the circle can be used to get the net horizontal force of the fluid on the inner surface of the hemisphere. Also think about the effect of external atmospheric pressure acting on the outer curved surface of the hemisphere.
Excellent thinking TSny !
Got the correct answer :oldsmile: .
And , yes ,its quite late here . But it is always a pleasure interacting with you .
TSny said:
OK. I guess we'll let Chet worry about the balance of torques. :smile:
Yes. To find out where the force has to be applied, you first need to get the moment of the pressure distribtuion around z = 0. You might be able to determine this from knowing the moment of inertia of a semicircle, without actually doing the integration. If not, get the moment the same way that TSny indicated to get the force.
Chet
Hello,
Could you please explain as to why the force exerted by external atmospheric pressure acting on the outer curved surface of the hemisphere would be PatmπR2 ?
Tanya Sharma said:
Hello,Could you please explain as to why the force exerted by external atmospheric pressure acting on the outer curved surface of the hemisphere would be PatmπR2 ?
The external atmospheric pressure acts perpendicular to the outer curved surface at each location on the surface. See what you get if you integrate this (vectorially) over the entire curved surface area of the hemisphere.
Chet
Chet's method will nail it.
A conceptual argument can be made that might or might not satisfy you. Imagine the atmosphere as a static fluid. Consider a hemispherical volume of the atmosphere with the flat surface of the volume oriented vertically. Consider the forces acting on the flat and curved surfaces of the volume due to the surrounding atmosphere. Argue that these forces must add to zero.
Chet
Do you mind showing how you would arrive at the result using above approach .
Yes ,that makes sense if we have same fluid on the flat and curved surfaces . But in the OP we have different fluids .
Can you think of an argument considering only the curved surface just like you did in post#8 :angel:?
The external atmospheric force acting on one of the hemispherical curved surfaces of the sphere filled with water is independent of what fluid is inside the sphere.
The left figure below shows a region of the atmosphere that has the same shape as a hemisphere of the sphere filled with water. The arrows indicate the external atmospheric force acting on the flat and curved surfaces of this portion of the atmosphere. The figure on the right is the sphere filled with water and the arrow indicates the external atmospheric force acting on the curved portion of one of the hemispheres of the sphere. All three forces F are equal. The force on the far left is easy to calculate.
