Mining Earth's Magnetic Fields with Satellites - Chris O'Connor
  • Thread starter Thread starter oconn1
    Satellite
Magnetic Anomaly Detectors (MAD) are known tools for geomagnetic surveys that can help identify mineral deposits, but their effectiveness diminishes with distance, making satellite use impractical. Instead, satellites are better suited for analyzing vegetation patterns to detect surface chemical traces indicative of underground resources. Recent discussions highlight the potential of meons, which may be used to locate heavy metals and nuclear materials, with ongoing developments in Japan for detecting seismic shifts and mineral concentration changes. While current satellite technology is limited, advancements are being pursued. The conversation emphasizes the need for closer proximity to accurately detect Earth's magnetic fields and mineral deposits.
oconn1
Hi, I would like to know if that there is any known ray or system that could be sent from a satellite down to Earth to read the Earth's magnetic fields to see high concentrations of precious metals in the ground?
In other words I would like to discuss the possibilities of sending a satellite into Orbit to detect high concentrations of precious metals for mining purposes.
Please reply promptly.
thanks,
Chris O'Connor
Yes! It is called a Magnetic Anomaly Detector (MAD).
Other uses
For geomagnetic survey work the detector can be mounted on a long probe in front of the aircraft or be a towed device. A chart is produced that geologists can study to determine the location and extent of mineral deposits.
http://en.wikipedia.org/wiki/Magnetic_anomaly_detector
Welcome to PF!
You probably wouldn't do it from a satelite though.
The field from a magnet falls off quite quickly with distance and there are lots of other electromagnetic fields in space that would swamp the system.
Gravity detection is also used but again from closer to the ground.
The main satelite resource use is looking at patterns of vegetation to spot surface chemicla traces which might indicate underground deposits.
you're absolutely right mgb_phys.
also just read about meon's the last months scientific american (the special edition with food and stuff) and it discussed how meons (look it up in astronomy) can be used to find nuclear material, but also heavy metals. thing is that they're going to use it in Japan to detect seismic shifts in the ground, through lava flows and shift in mineral concentrations in the ground. and although no detectors are available to do this in large scale from a satellite, the technology is under development.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
