Minkowski in 5-D: what is the fifth?
  • Thread starter Thread starter nomadreid
    Minkowski
nomadreid
In the equation for the Minkowski 5-D space in which deSitter space is embedded, I read the equation t^2 -x^2-y^2-z^2-v^2=-H^-2. What is v?
It's the fifth coordinate. De-Sitter-space is a 4 dimensional submanifold of R^5, or I should say R^(1,4) I guess.
Yes, I know it's the fifth coordinate. The question was whether one can represent it as any measurable quantity, as the other four are (3 spatial and one time). In string theory, of course, it is a rolled-up tiny other spatial dimension, but is this what is meant when discussing the 5-D Minkowski space of which the deSitter space is a submanifold?
While I am at it, I am still puzzling how one gets a positive curvature out of deSitter space if the metric on the deSitter space is the same as on the ambient Minkowski space, which gives a negative curvature.
It is just the space that the manifold is embedded in. It is still a 4 dimensional manifold on which you have to introduce coordinates before you do physics on it. It's just easier to describe as a submanifold, but it still represents an ordinary 4 dimensional world.
Just like the 2-sphere is described by x^2+y^2+z^2=1. There are three coordinates in the embedding space, but in the end you just introduce two coordinates to describe the manifold you are interested in, for example phi and theta. It doesn't make much sense to me to ask what "z" is "representing" in this case.
Thanks. Your example was illuminating.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
