News Miranda's Cliffs: Surviving a 12 Mile High Fall
  • Thread starter Thread starter zuz
Falling from one of Miranda's 12-mile high cliffs while wearing a spacesuit raises questions about survival due to the moon's low gravity, which is only 0.008 times that of Earth. The fall would take significantly longer than on Earth, with an estimated maximum speed of around 90 miles per hour. Calculations indicate that the impact velocity would be approximately 183 m/s, leading to a corresponding kinetic energy similar to a 139.84-meter fall on Earth, roughly equivalent to a 42-story drop. Factors such as age, mass, bone density, and overall fitness play crucial roles in survival outcomes from such falls. The discussion highlights the importance of understanding gravitational effects and the physics of free fall when considering the potential for survival in extreme scenarios.
zuz
If you fell off one of Miranda's 12 mile high cliffs. what would happen? Would you die? Assuming you are wearing an adequate spacesuit.
The jumper would max out at around only 90 miles per hour and might even be able to land safely with some sort of futuristic airbag!
The fall would take so much more time because Miranda is much smaller than Earth. That means it has less gravity. In fact, the gravity is only 0.008 times as strong there as compared to Earth.
-NASA
Likes Wrichik Basu, russ_watters and jim mcnamara
0.079 m/s² is the value given here:
https://en.wikipedia.org/wiki/Miranda_(moon)
as the acceleration due to gravity on the surface of Miranda.
Do you know to figure out the velocity at impact? This, in turn, gives you an approximate value for impulse. Sort of the amount "wham" you experience from impact. This would be what you have to survive.
@Keith_McClary gave you a nice answer using cartoons. Maybe that answers it.
You should also realize humans have limits that vary from person to person for surviving falls. Age is a big factor. Mass of the falling person. Bone density. Fitness. Couch potatoes likely will fare worse.
Surface gravity is ##a=GM/R^2## and escape velocity is ##v=\sqrt{2GM/R}##. For Miranda, ##v=183m/s## and equatorial radius is 235,800m. [That's the data I found at https://solarviews.com/eng/miranda.htm ] so we can calculate the surface gravity from the radius and escape velocity as ##a= v^2/2R = 33,489/(2\cdot 235800) = 0.07101145 m/s^2##. The surface gravity of Earth being ##9.80665 m/s^2## gives us a ratio of 0.00724.
So, since equivalent speeds (of impact) correspond to equivalent kinetic energies and that would correspond to equivalent potential energies of falling (mass times acceleration times distance fallen) we see that the 12 mile fall or 19,312 meter fall on Miranda equates to a 139.84 meter (459.8 foot) fall on Earth, (about 42 stories in standard building height). Not something I'd be willing to experience.
Likes Wrichik Basu and jim mcnamara
Thread 'In the early days of electricity, they didn't have wall plugs'
Hello scientists, engineers, etc. I have not had any questions for you recently, so have not participated here. I was scanning some material and ran across these 2 ads. I had posted them at another forum, and I thought you may be interested in them as well. History is fascinating stuff! Some houses may have had plugs, but many homes just screwed the appliance into the light socket overhead. Does anyone know when electric wall plugs were in widespread use? 1906 ad DDTJRAC Even big...
https://unionrayo.com/en/traffic-lights-color-white-autonomous-cars/ In this article, traffic researchers looking to improve traffic flow via autonomous cars and a 4th white light on the traffic light to signal that autonomous cars are controlling the light please follow their lead. Cue the Outer Limits theme song: “Do not attempt to control your television. We control the horizontal. We control the vertical. …”
