Rickeroo said:
Thanks Sylas.
With the correlation being .735, would that be enough to say that the comparision is relevant, or at least something to be looked at further?
It's enough to be suggestive; worth looking at. I would not be at all surprised to see some kind of temperature related effect, but as I said, it's a bit of a guess. I suspect that if we hunted through the literature on the carbon cycle we'd find some consideration of such effects. I don't know off the top of my head and I haven't take time to look.
Would that suggest that temperature leads carbon, at least to some degree?
Sure. If you look at the Mauna Loa data, you should see that the total atmospheric CO2 looks like a tilted sine wave. There is a very strong annual flux of CO2 in and out of the atmosphere every year, and then a steady continuous increase going on all the time as well.
In a way, the Earth "breathes". The effect is seasonal, and it arises mostly (I think) from changes in the way vegetation takes in and emits CO2 between winter and summer. The total flux of CO2 involved is huge.
However, it is not cummulative. The carbon taken into vegetation is released again later. There's a continual cycle of carbon between atmosphere, vegetation, soil and ocean, going on all the time. The human input is a bit different, because we are basically acting as a way for carbon from geological reserves (fossil fuels) to make its way into the carbon cycle, and this leads to a gradual increase in carbon in all parts of the carbon cycle: the atmosphere and ocean especially.
Basically, the carbon cycle consists of several "reservoirs" of carbon, each with a different total capacity, and with carbon fluxes between them. Here's a diagram, from an online textbook:
http://www.uwsp.edu/geO/faculty/ritter/geog101/textbook/earth_system/biogeochemical_cycles.html .) The numbers are the capacities of the reservoirs, and the total amount of carbon moving between them annually.
What human emissions do is add 5.5 GigaTonnes per year into the atmosphere. Over a century, this has resulted in a large increase in total carbon in the atmosphere, ocean and terrestrial reservoirs. But at the same time, there is about 90 Gigatonnes per year going each way between ocean and atmosphere, and about 120 Gigatonnes per year each way between atmosphere and vegetation/soil on land. Temperature effects can shift the balance of the reservoirs a bit, enough to make the net atmospheric increase rise or fall a bit, and I would guess this is the main reason for the correlation you have observed.
Cheers -- sylas
