I Modeling a ferromagnetic core moving inside a solenoid with scipy+FEMM
The discussion revolves around modeling the movement of a ferromagnetic core within a solenoid using FEMM and SciPy, focusing on the challenges of energy conservation in the system. The user describes their approach of running multiple static simulations to gather force and inductance data for interpolation, as FEMM cannot handle transient calculations. They detail the equations governing the system, including the relationships between distance, speed, voltage, and current, while expressing concerns about potential errors in their di/dt equation or interpolation methods. Suggestions from other participants highlight that numerical methods can lead to energy conservation violations, emphasizing the importance of accurate approximations in the modeling process. The user seeks further advice on their implementation and the numerical methods used.
mkaluza
TL;DR Summary
My model does not conserve energy and I have no idea what's wrong...
Hi,
I know, not another one, but I'm a more practical/engineering than scientific type - I need some tangible thing to learn stuff, so bear with me :)
Let me say hello first :)
The general idea was to model movement and electrical stuff with diff equations and do the hard part with femm. The thing is that since femm can't do transient calculations, I decided to run multiple static simulation for various projectile positions and various currents and store force and inductance to interpolate them later. This way I got F(x, i) and L(x, i) that I'm later using in scipy.
I get them from FEMM like so:
fz=femm.mo_blockintegral(19)
val1, val2, val3 = femm.mo_getcircuitproperties(self.name)
CoilResistance = val2/val1 # Calculate the ohmic resistance of the coil
CoilInductance = val3/val1 # Calculate the inductance of the coil
The electrical part of the model is just a charged capacitor C discharged into a coil and a serial diode to prevent the current from oscilating.
The problem I have is that the model does not conserve energy, so sth is obviously wrong, but I don't know what - either my di/dt equation or the interpolation, or... ???
vars: x (distance between coil and core centers), v (speed), u (cap voltage), i (current)
equations:
dx/dt = v
dv/dt = F(x, i)/m
du/dt = -i/C
To get di/dt I did:
u = iR + (d/dt)[L(x, i) * i]
u = iR + L(x, i)*di/dt + i * (d/dt)L(x, i)
but since both x and i are time dependend, I then did:
u = iR + L(x, i)*di/dt + i * [(δ/δx)L(x, i) * dx/dt + (δ/δi)L(x, i) * di/dt]
u = iR + L(x, i)*di/dt + i * (δ/δx)L(x, i) * dx/dt + i * (δ/δi)L(x, i) * di/dt
i * (δ/δi)L(x, i) * di/dt + L(x, i)*di/dt = u - iR - i * (δ/δx)L(x, i) * dx/dt
finally:
di/dt = (u - iR - i * (δ/δx)L(x, i) * dx/dt)/(i * (δ/δi)L(x, i) + L(x, i))
is that correct?
Resulting python func then fed to solve_ivp is:
def Fsim(t, X):
x, v, u, i = X
#core movement
dx_dt = v
dv_dt = A_i_x(i, x)[0][0] #A - just precalculated F(i, x)/m
#electrical circuit
du_dt = -i/C
di_dt = (u - i*R - i*v*dL_dx(i, x)[0][0])/(L_i_x(i, x)[0][0] + i*dL_di(i, x)[0][0])
if u <= 0 and i <=0: di_dt, du_dt = 0, 0 #serial diode
Y = [dx_dt, dv_dt, du_dt, di_dt]
return Y
the interpolation I use is by scipy.interpolate (yes, x and i are reversed):
F_i_x = RectBivariateSpline(I, Z, F)
A_i_x = RectBivariateSpline(I, Z, F/m)
L_i_x = RectBivariateSpline(I, Z, L)
dL_dx = L_i_x.partial_derivative(0, 1)
dL_di = L_i_x.partial_derivative(1, 0)
Link is to a zip file with precalculated data (those take a while...)
https://drive.google.com/drive/folders/1ACgUDOIAxobmZePrDnr4ZCaKOkDH52sO?usp=sharing
Complete code and sample charts attached.
Any suggestions will be very welcome :)
Are you solving the differential equation numerically?
Are you using your own code to solve the equation or are you using the predefined libraries?
Numerical methods provide approximations that violate the conservation of energy. This violation is more or less evident depending on how good the approximation is.
Here is a related video that explains what I'm trying to say.
Your problem could be another though. I'm not experienced enough to judge only from what you wrote.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
