Modeling the concentration of gas constituents in a Force Field
The discussion revolves around modeling the concentration of gas constituents in a rectangular container subjected to a homogenous force field that selectively affects one type of gas molecule. Participants explore the implications of this setup on the concentration profiles of two gas molecules, A and B, at thermal equilibrium, considering both height and time factors.
  • One participant describes a gas mixture of Molecule A and Molecule B, with Molecule A being affected by a downward force field while Molecule B remains unaffected, leading to varying concentrations with height.
  • Another participant questions whether the difference in molecular weights between the two species would significantly impact the concentration distribution in the presence of the force field.
  • Several participants confirm the assumption of an ideal gas mixture, noting that the ideal gas law applies without considering intermolecular forces.
  • A participant asserts that in an ideal gas mixture, each constituent behaves independently of the others, leading to the conclusion that partial pressures can be calculated separately and summed to find total pressure.
  • One participant suggests that understanding the relationship between pressure, density, and species concentration is crucial for modeling the system, prompting further exploration of these relationships.
Participants generally agree on the assumption of ideal gas behavior and the independence of constituents in an ideal gas mixture. However, there remains uncertainty regarding the impact of molecular weight differences on concentration profiles and the specific mathematical modeling of the system.
Participants express uncertainty about the mathematical description of the concentration variations and the specific conditions under which the assumptions hold, particularly regarding the effects of the force field on the gas constituents.
This discussion may be useful for those interested in gas dynamics, thermodynamics, and the behavior of gas mixtures under non-uniform force fields, particularly in theoretical and experimental contexts.
Anon42
Say there is a gas made up of two gas molecules: Molecule A and Molecule B.
Molecule A has a mass: ma and mole fraction: na.
Molecule B has a mass: mb and mole fraction: nb.
The gas is at thermal equilibrium and has a constant temperature throughout itself (T) everywhere. It is placed in a Rectangular container of width w and height h. There is a homogenous force field applied to the container of the gas along its height pointing downward. (Like gravity). This field, unlike gravity, does not affect all molecules. This field only exerts a force on Molecule A in the gas, and does not affect Molecule B.
If there were no field applied, concentrations of each molecule at a certain height would be the same throughout the container, and they would just be equal to their mole fraction. However with the applied field, that only affects one type of molecule, the concentrations would vary with respect to the height of the container. Is there an equation that models the concentration of gas constituents at equilibrium as a function of height in a field like this? Or better yet, is there one that models those concentrations as a function of height and time assuming the container starts with a perfectly mixed gas once the field is applied.
I know there is an equation to model concentrations of various gasses in a gravitational field as a function of height. However that equation does not apply to this case because it assumes the force field applies to all molecules in the gas equally.
This attached PNG shows a container filled with a gas comprised of two types of molecules. The large "g" I drew on the left with an arrow pointing down shows what direction that field would be. That field would only apply to either the red or the grey molecules in that gas, and leave the other species alone. na(z) is the mole fraction of Molecule A as a function of container height.
Science news on Phys.org
Hi,
Would the zero gravity for one species make much difference in the case the molecular weights are very far apart (e.g. H2 and Xe) ?
Are you assuming that this is a mixture of ideal gases?
Yes I am. Nothing like the Van der Waals equation of state used to describe this gas, just the ideal gas law.
BvU said:
Hi,
I don't know that it would. I assume that it would if the molecular weights are far apart, but I do not know by how much, or how I would go about describing this mathematically.
Anon42 said:
Yes I am. Nothing like the Van der Waals equation of state used to describe this gas, just the ideal gas law.I don't know that it would. I assume that it would if the molecular weights are far apart, but I do not know by how much, or how I would go about describing this mathematically.
True or false: In an ideal gas mixture, each constituent behaves as if the other constituents are not even present.
I want to say True. Since there are no intermolecular forces the ideal gas law depends only on the amount of gas molecules that are in a gas, and not the properties of any of its constituent gases. This is where the partial pressure law comes from. If only the amount of gas influences the pressure and nothing else. Partial Pressures of various constituents can be calculated as if other constituents were not there, and then be summed together to get the total pressure.
In short, True: In an ideal gas mixture, each constituent does behave as if the other constituents are not even present.
Then you should have no problem solving your problem.
Let z be the distance measured upward from the base of your container, and A be the cross sectional area of your container. According to the relationship between pressure and depth, how is the vertical partial pressure gradient related to the density of a species? From the ideal gas law, how is the partial pressure related to species density? How is the total mass of a species in the container related to its vertical density variation?
  • · Replies 0 ·
  • · Replies 109 ·
10K
  • · Replies 23 ·
