Proofing the Modulation Index for AM Transmission
  • Thread starter Thread starter commelion
    Index Modulation
The discussion focuses on deriving the modulation index for amplitude modulation (AM) transmission, specifically using the equations Vmax = a(1+u) and Vmin = a(1-u). The modulation index, represented by 'u', quantifies the information in the total power transmitted and should always range between 0 and 1. A participant suggests solving the simultaneous equations by adding and subtracting them to simplify the process of finding 'u'. The original poster expresses frustration with the mathematical complexity but is encouraged to try this method. The conversation highlights the importance of clear mathematical steps in understanding modulation index calculations.
commelion
ive been trying to proof the modulation index for Am transmission, it goes like this
Vmax = a(1+u)
Vmin = a(1-u)
it basicilly describes the amount of infromation in the total power transmitted and should allways be between 0 & 1
eventually the answer should come out to be
u = (Vmax-Vmin)/(Vmax+Vmin)
its the maths in between that is anoying the hell out of me, if anybody has any info on doing this please help, I've tried matrices so don't bother ! :bugeye:
thanks in advance.
worse than useless response
it does not address the question what so ever, but thanks anyway
You just need to solve the two simultaneous equations that you have at the beginning of your first post:
Add them and then subtract them, then take the ratio to get u- it falls out in three lines.
ok thanks ill try that
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
