Molecular speed and temperature
A hypothetical air filter that only allows faster-moving air molecules to exit and slower ones to enter would create a temperature imbalance, cooling the inside of a house while heating the outside. This scenario directly challenges the second law of thermodynamics, which states that entropy in a closed system cannot decrease. The concept is reminiscent of Maxwell's demon, a thought experiment that illustrates similar thermodynamic principles. However, it is concluded that such a filter cannot be constructed in reality. The discussion emphasizes the impossibility of violating established thermodynamic laws.
Himanshu_6174
Imagine a special air filter placed in a window of a house. The tiny holes in the filter allow only air molecules moving faster than a certain speed to exit the house, and allow only air molecules moving slower than that speed to enter the house from outside. What effect would this filter have on the temperature inside the house?
Science news on Phys.org
Google for "Maxwell's demon".
Essentially, this filter violates the second law of thermodynamics by cooling the house and heating up the outside, even if it is already warmer outside than inside the house. This is very similar to a thought experiment known as "Maxwells Demon", as mentioned by Nugatory.
Essentially, there is no way to construct such a filter.
Thanks :-) both of you
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
