Moment of Inertia: Calculation Method
3 replies · 2K views
Benjamin_harsh
Ratio of moment of inertia of a circle and that of a square having same area about their centroidal axis is:
Why they calculated ##\large\frac{d}{a}## in first step?
Sol: both area and square have same area:
##a^2 = \large\frac{π}{4}\normalsize d^{2}; \large\frac{d}{a} =\large \sqrt\frac{4}{p}##
Ratio of moment of inertia of a circle and that of a square about their centroidal axis is:
##\large\frac{I_{c}}{I_{s}} = \large\frac{\frac{π}{64}d^4}{\frac{a^{4}}{12}} = \large\frac{12π}{64}\frac{d}{a}^{4}##
##\large\frac{3π}{16}(\sqrt\frac{4}{p})^{4} = \frac{3}{π}##
on Phys.org
These questions you are working through keep referring, ambiguously, to "the" centroidal axis. I have tended to assume they mean the one normal to the plane. In the present question it doesn’t matter whether it is that axis or any axis in the plane as long as the choice is consistent, but looking at the detailed calculation they seem to be referring to an axis in the plane. If they meant normal to the plane then both values would be doubled.
Interesting...
Correction in last step: ##\large\frac{3π}{16}(\sqrt\frac{4}{π})^{4} = \large \frac{3}{π}##.
