Moment of Inertia, for Load along Z-Z axis?
The discussion focuses on calculating the Moment of Inertia for a C-Channel subjected to loads along the Z-Z axis. Participants clarify that when the load is axial, the primary concern is P/A stresses, but if the loading is eccentric, it introduces weak axis bending stresses. The Perpendicular Axes Theorem is referenced, with specific inquiries about whether Izz can be calculated as Ixx + Iyy. The consensus indicates that Izz is relevant when considering torsional effects due to non-central loading.
  • Understanding of Moment of Inertia concepts
  • Familiarity with the Perpendicular Axes Theorem
  • Knowledge of axial loading versus bending stresses
  • Basic principles of structural mechanics
  • Research the application of the Perpendicular Axes Theorem in structural analysis
  • Study the effects of eccentric loading on Moment of Inertia calculations
  • Learn about torsional effects in C-Channels under axial loads
  • Explore advanced structural analysis techniques for non-uniform loading conditions
Structural engineers, mechanical engineers, and students studying mechanics of materials who need to understand the implications of loading conditions on Moment of Inertia calculations.
subbby
Assuming that I have a C-Channel
When the load acts along the X-X axis, we take Iyy for the Bending moment calculations. Similarly, when load acts along the Y-Y axis, we take Ixx. But if i have a load that acts on Z-Z axis, how do I calculate the Moment of Inertia?
PLS SEE THE ATTACHMENTS in the following SEQUENCE
FIRST : Attchmnt : TOP VIEW
SECOND : Attchmnt : DETAIL A
THIRD : Attchmnt : ELEVATION
My specific Doubts:
  1. Do I have to take Izz?
  2. If yes, is Izz=Ixx+Iyy (applying Perpendicular Axes Theorem)
Can Anyone help me?
Loading along the z axis would be axial loading (P/A stresses, not bending stresses) except if the axial loading is eccentrically applied (I am not sure if it is) , then it would create weak axis bending stresses as well.
Quote: Similarly, when load acts along the Y-Y axis, we take Ixx end quote
When load is along y-axis, this member will bend about xx but will also twist about zz because it is not being loaded through its shear centre. That involves Izz as well as Ixx/
  • · Replies 24 ·
  • · Replies 16 ·
73K
