Moment of inertia tensor about y-axis of a cylinder.
The discussion focuses on determining the ratio of height to radius of a cylinder such that every axis is a principal axis with the center of mass as the origin. The moment of inertia tensor is central to this analysis, specifically the equation I_yy = ∑ m (x² + z²). The participant calculated I_zz as MR²/12 but noted that this value is incorrect and requires adjustment. The use of cylindrical coordinates is recommended for the integration process to accurately derive the moment of inertia tensor.
  • Understanding of moment of inertia tensor
  • Familiarity with cylindrical coordinates
  • Knowledge of integration techniques in physics
  • Basic principles of mechanics
  • Review the derivation of the moment of inertia tensor for various shapes
  • Study the application of cylindrical coordinates in physics problems
  • Learn about principal axes and their significance in mechanics
  • Explore common mistakes in calculating moment of inertia
Students studying mechanics, particularly those focusing on rotational dynamics and moment of inertia calculations, as well as educators looking to clarify concepts related to principal axes in rigid body motion.
rsaad
What must the ratio of height to radius of a cylinder be so that every axis
is a principal axis (with the CM as the origin)?
Moment of inertia tensor.
I need I_yy = \sum m *(x^2 + z^2)
I calculated I_zz = MR^2 /12 . Now I change the principal axis to y-axis. I need to determine the moment of inertia tensor of it. Polar coordinates won't work. If I go for cartesian, I do not know the limits for the dx.
You can perform the integral using cylindrical coordinates ##\vec{r} = (r\cos\theta, r\sin\theta, z)##.
Also, the result for ##I_{zz}## is not correct. You should get a different factor than 12 in the denominator.
  • · Replies 30 ·
  • · Replies 40 ·
