Moment of Inertia vs. Inertia Constant
The discussion clarifies the definitions and calculations related to the inertia constant (H) and moment of inertia (J) for synchronous machines. The inertia constant is defined as H = (1/2 J ω₀²) / S, where S is the rated power in megawatts and ω₀ is the nominal angular frequency. The confusion arises from the units of J, which should be expressed in kg m², while the derived units from the equation yield seconds MW/(rad²/s²). The participants emphasize the importance of using watts instead of megawatts to avoid unit discrepancies.
  • Understanding of synchronous machine dynamics
  • Familiarity with the concept of moment of inertia
  • Knowledge of angular frequency and its units
  • Basic grasp of unit conversions in physics
  • Research the derivation of the inertia constant for synchronous machines
  • Study the relationship between power units (W vs. MW) in electrical engineering
  • Learn about the significance of radians as a unit in rotational dynamics
  • Explore graphical representations of angular measurements and their applications
Electrical engineers, mechanical engineers, and students studying power system dynamics will benefit from this discussion, particularly those focused on synchronous machine performance and unit analysis.
hansherman
The following equations are found in the following reference (Page 119):
http://www.eeh.ee.ethz.ch/fileadmin/user_upload/eeh/studies/courses/power_system_dynamics_and_control/Documents/DynamicsPartI_lecture_notes_2012.pdf
By definition, the inertia constant for a synchronous machine is defined as
H = (1/2 J \omega_0^2) / S
where
a) H= \text{constant of inertia } (s)
b) S = \text{rated power of synchronous machine } (MW)
c) \omega_0 = \text{nominal angular frequency } (rad/s)
d) J = \text{moment of inertia for rotor } (kg m^2)
I.e.
J = 2HS/\omega_0^2
can be used to find the moment of inertia. Based on the units of a), b) and c) the unit of J is
s MW/(rad^2/s^2)
However, i cannot see that this is the same as kg/m^2, as the result is supposed to yield from d). Can anyone help me?
Hint #1: Radians are unit less, so you can drop that term.
Hint #2: The watt (and hence megawatts) is a derived unit. What are its primitive units?
Hint #3: Instead of using MW (megawatts) you should just use W (watts). M is just a numerical factor of 1000000 and therefore is unitless. The Watt is the standard unit of power for the metric system.
There is no reference to this on page 119.
However, the quantity defined in your post have units of seconds (energy/power).
The confusion may be due to the fact that (at least) two different quantities may be called the same name: "inertia constant".
See for example here:
http://books.google.ca/books?id=Su3...onepage&q=inertia constant of machine&f=false
You are talking here about the second quantity, the H defined on page 540 of that book and not the first one (I*ω) which is also called inertia constant, on the same page.
I do not understand why Radians are unit less. Can anyone explain this? Thanks for the answers.
Because you divide [Length] by [Length]
θ = s /r
s is arc length (of a circle)
r is radius
EDIT:
This page has a nice graphical (animated) explanation about the radian:
http://ru.wikipedia.org/wiki/Радиан
  • · Replies 16 ·
