Moment of Intertia for changing COG
A 3D object modeled in Pro/Engineer has a tail that can change position, and a closed-form solution for the center of gravity at any angle theta has been developed. The challenge lies in expressing the moment of inertia about the vertical axis in relation to the center of gravity's location. It is noted that the inertia of the body without the tail remains constant, while the tail's inertia can be calculated as a function of the angle. However, calculating this may not be straightforward unless the tail is a simple geometric shape. Understanding these relationships is crucial for accurate modeling of the object's dynamics.
r00bin
Hi all,
I've got a 3d object modeled in Pro/Engineer with a tail. The tail can change position to some angle theta with respect to the ground.
I have created a closed form solution to determine the location of the center of gravity at any angle theta.
The problem is with the moment of inertia. From Pro/Engineer, I can numerically determine the moment of inertia about the vertical axis at the center of gravity.
Is there anyway to express the moment of inertia about the vertical axis as a function of the center of gravity location?
Thanks!
Yes. The inertia of the body (without tail) is fixed. Then all you need to do is find out the inertia of the tail about the vertical axis as a function of angle. You can easily relate the angle to the change in CG.
Won't be a trivial calculation unless the tail is some sort of elementary shape.
Thread 'Question about pressure of a liquid'
I am looking at pressure in liquids and I am testing my idea. The vertical tube is 100m, the contraption is filled with water. The vertical tube is very thin(maybe 1mm^2 cross section). The area of the base is ~100m^2. Will he top half be launched in the air if suddenly it cracked?- assuming its light enough. I want to test my idea that if I had a thin long ruber tube that I lifted up, then the pressure at "red lines" will be high and that the $force = pressure * area$ would be massive...
I feel it should be solvable we just need to find a perfect pattern, and there will be a general pattern since the forces acting are based on a single function, so..... you can't actually say it is unsolvable right? Cause imaging 3 bodies actually existed somwhere in this universe then nature isn't gonna wait till we predict it! And yea I have checked in many places that tiny changes cause large changes so it becomes chaos........ but still I just can't accept that it is impossible to solve...
