Momentum and Force: Solving Problem with Springs
In summary, the force acting on a person wearing springs on their shoes who jumps high in the air and lands is due to the rate of change of momentum. When the person has gained momentum while falling, the net force is zero, but as the spring is compressed, the net force becomes an upward force, which begins to decrease the downward momentum. The important thing to remember is that zero force does not mean zero motion, but rather that the momentum is not changing.
Bengo
46
I've come across a few problems where it seems like momentum is acting like a force. For instance take a man wearing springs on his shoes who jumps high in the air and lands. The force down is mg and as he compresses the springs the force up is kx. At some point mg=kx but how can the man continue to compress the springs? Where does this force come from? Does this have to do with momentum or am I way off here? Thank you
Force is the rate of change of momentum with respect to time (##\frac{dp}{dt}## if you've had calc). In the (semi)static case ##(p=0)\ \ mg=kx## would be the farthest the person compresses the spring. When the person has gained momentum while falling, this is only the point where the (magnitude of the) momentum starts to decrease. When ##mg=kx##, the net force is zero. As the spring is compressed more, the net force becomes an upward force which begins to decrease the downward momentum. The important thing to remember is that zero force does not mean zero motion (and thus momentmum). Zero force means that the momentum is not changing. Does that clear things up?
Likes 1 person
That does clear things up. Thank you very much
FAQ: Momentum and Force: Solving Problem with Springs
1. What is momentum and force?
Momentum is a measure of an object's motion, calculated by multiplying its mass and velocity. Force is a push or pull on an object that can change its state of motion.
2. How do springs affect momentum and force?
When a force is applied to a spring, it can store potential energy and deform, which can then be released as kinetic energy when the force is removed. This affects the object's momentum by either increasing or decreasing its velocity.
3. How do you solve problems involving springs, momentum, and force?
To solve such problems, you must first identify the known values, such as the mass of the object, the spring constant, and the amount of force applied. Then, you can use equations of motion and Hooke's Law to calculate the resulting momentum and force.
4. What is Hooke's Law and how does it relate to springs?
Hooke's Law states that the force exerted by a spring is proportional to its displacement from its equilibrium position. This means that the more a spring is stretched or compressed, the greater the force it exerts. This law is important in understanding the behavior of springs in relation to momentum and force.
5. Can you give an example of a real-life application of solving problems with springs, momentum, and force?
One example is a car's suspension system, which uses springs to absorb the impact of bumps in the road. When the car hits a bump, the springs compress and store energy, which then gets released as the car moves over the bump. This helps to maintain the car's momentum and reduces the force felt by the passengers.
