Matterwave said:
I don't believe HUP would allow you to measure a perfectly precise momentum, as that would imply, somehow, an infinite uncertainty in position.
This has been discussed here recently, but I can't find the thread just now, so I will summarize the content.
This is one of those subtle issues, but it is real and not just semantic. Say you have a free particle represented by some wavepacket with a finite width \Delta p. That momentum distribution represents all of the possible momentum eigenstates that could be measured. However, it is a fundamental postulate of QM that when the measurement is conducted, a single eigenstate is projected out of the wavefunction, \left\langle k | \psi\right\rangle, where k=2\pi/\lambda indexes a free particle momentum eigenstate. This measurement can be conducted with arbitrary precision, independent of the width of the starting wavepacket in momentum space. Where the HUP comes in is in determining the probability of measuring that state, which is given by \left|\left\langle k | \psi\right\rangle\right|^{2}. So, if you conducted the same measurement again from another identical wavepacket, there is an overwhelming probability that you would measure a
different eigenstate.
Thus the HUP tells us only about the probability of a single measurement, or what to expect from a series of measurements with identical starting conditions. It says nothing about the value, or the measurement uncertainty, of a particular measurement.
If there is an infinite uncertainty in the position...what are you measuring?
That is a fair question, but note that it refers to the situation *after* the measurement has occurred. So, it would have no relevance in the case where the particle was detected by splatting it onto a detector screen, since that event "destroyed" the wavefunction of the particle, or at least perturbed it severely into some completely different space. On the other hand, if the particle momentum was measured in a scattering experiment, then it does make sense to talk about the wavefunction after the measurement. However in that case, you defer the
actual measurement to the probe particle, which again can be measured with arbitrary precision. The momentum of the target particle after the scattering event will not be known precisely in this case, but will be represented by a distribution that can be determined from a
set of such measurements to reveal the momentum distribution of the probe particle, and we are in the same situation as above for the direct measurement.
I hope this is clear ...
