Monostable multivibrator no input, the transistor1 in active mode?
  • Thread starter Outrageous
    Input Mode
5 replies · 2K views · last reply
Outrageous
If T1 is in active mode all the time, will there be any current flow in this circuit? ( I think it is impossible to flow) thanks
  • Hand-drawn schematic of a monostable multivibrator with two NPN transistors T1 and T2, collector resistors Rc1 and Rc2, base resistor RB2, timing resistor R, capacitor C, supply Vcc, outputs VA and VB, and a diode with a trigger input capacitor at lower left.
If T1 is on then the circuit will remain stable until... The input on the bottom left has a capacitor in series with a diode. The first negative input pulse will charge the input capacitor and flip T1 to off, but that can happen only once.
If T1 is in the active region, there will be current flowing✻ in RC1 and R at least.
✻ assuming the lower horizontal line is connected to a suitable voltage rail[/size]
If there is no pulse, and the whole is only supply with Dc and there are capacitors inside, how will the current move?
Thanks, guys
If there is no negative pulse ,the whole circuit is only powered by Dc ,and there are capacitor inside, how will the current flow?
This sounds like a homework exercise.
It is a standard monostable multivibrator circuit. I am confident that a google search will
find its operation well-described. http://img811.imageshack.us/img811/5412/thgooglefriend1.gif
