What is the Value of k in This SAT Math Problem?
  • Thread starter Thread starter I'm
    Sat Sat math
To solve for k in the equation (n/(n-1)) x (1/n) x (n/(n+1)) = 5/k, the left side simplifies to n/(n^2 - 1). This leads to the equation n/(n^2 - 1) = 5/k. Rearranging gives (n^2 - 1)/n = k/5. This indicates that k can be expressed as k = 5(n^2 - 1)/n for positive integers n and k. The discussion focuses on finding the correct value of k based on the derived formula.
I'm
(n/(n-1)) x (1/n) x (n/(n+1)) = 5/k for positive integers n and k, what is the value of k>
I multiplied the left side out to be (n/(n^2-1) and set it equal to 5/k
I got stuck right there.
So what you've gotten is, n/(n2 - 1) = 5/k
If that's true, then we should have,
(n2 - 1)/n = k/5
Since we know that n != 0
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
