Mosfet Load switch + weird load
The discussion revolves around the behavior of an N-channel MOSFET load switch used to control a WiFi module on a circuit board. Participants explore the unexpected voltage observed at the load when the switch is turned off, specifically focusing on the peculiarities of the WiFi module compared to other loads.
  • Experimental/applied
  • One participant reports a voltage of 1.4V at the load when the MOSFET is off, which decreases to 1.1V after changing the bleed resistor from 1k to 100 ohms.
  • Another participant questions the voltage across the MOSFET when it is off, suggesting it should be 3.3V and raises concerns about using an N-channel MOSFET for ground-connected loads.
  • A participant notes that the voltage across the MOSFET is 1.9V when the load shows 1.4V, prompting further inquiry into the advisability of the circuit configuration.
  • Suggestions are made to check the collector-emitter (CE) voltage of a 2222 transistor, with recommendations to ensure it is driven to saturation or to replace it with a logic level FET.
  • Concerns are raised about potential issues with signal connections to the 3.3V module, particularly regarding biasing protection diodes or parasitic structures when the load is off.
  • Another participant speculates that the MOSFET might not be saturating properly or that the WiFi module could be floating a small voltage.
  • One participant confirms that the CE voltage is low (50-100mV) and that grounding the MOSFET gate did not resolve the issue, maintaining a 1.4V reading at the load.
  • Another participant suggests the possibility of the MOSFET being damaged due to static electricity, recommending testing with a previously functioning module.
  • Clarification is provided that off-state voltage levels should be at 0V, not 3.3V, and that driving signals outside of the power supply rails can lead to issues.
  • A later reply asserts that the FET is functioning correctly and shows no signs of damage.
Participants express varying opinions on the cause of the voltage issue, with some suggesting potential circuit design flaws and others considering the possibility of component failure. No consensus is reached regarding the underlying problem.
Participants note the importance of ensuring proper saturation of components and the risks associated with signal connections to the module. The discussion highlights the complexity of the circuit behavior without resolving the specific cause of the observed voltage.
likephysics
I have a N-ch Mosfet load switch that connects to a WiFi module on a circuit board.
When the switch is turned OFF, I still see a voltage of 1.4V at the load.
Ckt attached.
I decreased the bleed resistor from 1k to 100 ohms. The off voltage decreased to 1.1v.
This doesn't happen with other loads like cellular modules, only with a particular WiFi module (WPER-172GN).
I don't have other wifi modules at the moment.
The N-Ch Mosfet is DMN1019
The WiFi module is WPER-172GN. The IC is Ralink RT5390. Cannot find Datasheet online!
The cellular module is EM820W and others. None of them gave me problems.
I can't figure out what kind of load would make the circuit behave like this.
What's your voltage across the mosfet when it's Off? Is it actually 3.3? Are you sure?
I will preface this by saying I'm not an engineer I'm only a student, but as I understand it it is inadvisable to drive ground connected loads with an n channel.
Across the Mosfet, I get (3.3 - the voltage at the wifi module). If the voltage at the load is 1.4v (when switch is off), the voltage across Mosfet is 1.9v
Why is it inadvisable to drive ground connected loads with N ch?
The ckt works for every load except the wifi module.
Check the CE voltage of the 2222. You may find that you are not driving it to saturation. If this is the case then you could be using the FET in its linear region depending on the load current. This is not what you want. Try replacing the 2222 with a FET. You will need a very small gate resistance or use a logic level FET such as BSS138 where you shouldn't need a gate resistor at all. Reducing the 2222 base resistor to bring it to saturation will work as well.
Do you have any signals connected to the 3.3V module back to the 5V section? You have to be careful not to drive any signal connected to the 3.3V module outside of power supply pins. When you have the load module off it has all of it circuitry at 3.3V. If any of the pins connected to the active parts are driven to anything other than 3.3V then you are in danger of biasing the protection diodes or parasitic BJT structures. That is generally not a good idea (you can lose the magic smoke!).
BoB
Sorry i didn't get back to you. I was thinking along the same lines as rbelli above me though, that somehow you're not saturating the fet. Maybe the chip floats a small voltage for some reason? Shouldn't but you never know...
I checked the CE voltage, it's about 50-100mV. I even grounded the Mosfet gate. But I still see 1.4V at the load.
I also connected Mosfet gate directly to LAB power supply and manually varied the voltage from 0 to 5V. But no change.
BoB
I double checked this too. No signals connected. The mini PCIe connector has provision for 5V, but the corresponding pins on the module are NC. Just to eliminate any possibility of this 5V getting into module, I lifted the connector pins off the board. No use though.
Maybe you fried the FET? They can be very sensitive to static electricity. Try switching back to a module that worked in the past.
BoB
PS: Regarding off state voltage levels. They will be at 0 not 3.3 like I said (too late at night!). Driving them outside of the rails has the same consequences in either case.
BoB
The FET is working fine. No damage.
  • · Replies 42 ·
  • · Replies 33 ·
  • · Replies 24 ·
