Motion of a Charged Particle in an Electric Field
The problem involves the motion of a proton in a uniform vertical electric field, focusing on its horizontal and vertical displacements and velocity components. The context is within the subject area of electromagnetism and kinematics.
  • Participants discuss the relationship between horizontal motion and vertical forces, questioning whether the proton maintains constant horizontal velocity. They explore how to calculate time intervals and vertical displacement, considering the effects of the electric field on acceleration.
Some participants have provided guidance on the relationship between electric field strength and acceleration, while others have confirmed the correctness of certain assumptions. There is ongoing exploration of the calculations related to vertical displacement and velocity components.
Participants are navigating the implications of ignoring gravitational effects and confirming initial conditions, such as the initial vertical velocity being zero. There is also a focus on ensuring the correct application of kinematic equations in the context of the electric field.
zandbera
A proton moves at 4.50 x 108 m/s in the horizontal direction. It enters a uniform vertical electric field with a magnitude of 9.60 x 103 N/C. Ignoring any gravitational effects, find (a) the time interval required for the proton to move 5.00 cm horizontally, (b) its vertical displacement during that time interval, and (c) the horizontal and vertical components of its velocity after it has traveled 5.00 cm horizontally.
[tex]\vec{a}[/tex] = q[tex]\vec{E}[/tex] / m
(a) Since it's moving at constant horizontal velocity, and the only force its encountering is a vertical force, would the particle continue to move at the constant horizontal speed? Which would mean that the time interval to move 5.00 cm is just its velocity / 5.00 cm??
(b) I don't know how to relate the electric field to the velocity. But I know that the initial vertical velocity is 0, right?
(c) If i was right in (a) then its horizontal component will be the same
Right.
You have that fraction upside down. Distance = velocity*time.
But you know how to find the acceleration caused by the electric field. The rest is kinematics.
Right.
That's true.
(b) From the equation and my given data, is qE = 9.60 x 10^3 N/C or is it just E = 9.60 x 10^3?
If it's E = 9.60 x 10^3, I would just multiply by (+e) to get qE and then divide by the mass of a proton, right?
Okay yeah for (b) I did what I thought, I used E = 9.60 x 10^3, then multiplied by +e, divided by mass of proton to get a, then used delta x = Vi t + 1/2 a t^2 with Vi = 0, and i got 5.68 mm, the correct answer.
So then for (c), the horizontal component is just the initial horizontal velocity, and then i can use the time interval from (a) and the acceleration from (b) to find the vertical velocity, so would those be my two components?
Right!
  • · Replies 31 ·
