Motion of a non-linear pendulum with air resistance
The discussion revolves around modeling the motion of a non-linear pendulum while accounting for air resistance. Participants are exploring the dynamics involved, particularly focusing on the forces acting on the pendulum and the resulting equations of motion.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to derive an equation based on forces, including gravitational and drag forces. Participants question the behavior of the graph produced and the nature of damping in the system. There are discussions about the correct formulation of the drag force and its dependence on velocity.
Participants are actively engaging in refining the equation and addressing potential sign errors in the forces. Some guidance has been offered regarding the treatment of the drag force and its direction relative to velocity. Multiple interpretations of the damping behavior are being explored, with no explicit consensus reached yet.
There are references to specific graphing domains and the need for clarity on the number of cycles observed. The discussion also highlights the importance of absolute values in the drag force equation and the implications of sign conventions in the forces acting on the pendulum.
Omkar Vaidya
I need to come up with an equation that would model the motion of a non-linear pendulum with air resistance. [/B]
Fc=mgsintheta
Fdrag=(1/2)p(v^2)CA
I started with mgsintheta-(1/2)p(v^2)CA=ma
After substituting v=r*omega and a=r*alpha, I get the following (look at the image)
i6bfv0
However, after graphing, I do not get a damped oscillating curve, because of the v^2 not changing signs. Can someone guide me? See second image:
i6bh0j
http://prntscr.com/i6bh0j[/B]
https://prnt.sc/i6bfv0
Sorry, we can't see the 1st image
To know whether there is a problem, how many cycles did you follow it through?
I'm not quite sure what you mean by cycles. I set the domain on the graph to be [0, 2pi].
To be sure there is no damping try 20π or 100π?
It does make sense that your damping doesn't work if the damping force is always pointing in the same direction and not against v. Maybe you should try to replace v^2 by |v|v.
I did, and there does not seem to be any. However, the amplitude does seem to change, but on average it remains the same.
Thanks, this does work. For some reason I didn't think of the absolute value as a solution to the v^2 problem. Now I get a graph that looks like the following. It does not pass through the x-axis like it should.
https://prnt.sc/i6cgpx
Another sign error. When you're at positive theta, the force must point in the negative direction. So it should be -mgsin(theta).
yes, I thought I already changed that. Thanks again.
Did you look at the derivation of that equation I came up with? I just need someone to check if its correct (apart from the signs, and absolute values)
Seems fine to me.
Gigaz said:
Seems fine to me.
Here is what I get using Maple to solve the IVP
$$\theta^{''} = -\frac{g}{L} \sin(\theta) - \frac{pLcA}{2m} \theta' |\theta'|, \; \theta(0)=1.5, \theta'(0)=0$$
using your input parameters (but using notation ##w(t)## instead of ##\theta(t)##):
Thread moved. Problems involving differential equations belong in the Calculus & Beyond section.
