MTW Gravitation: Exercise 5.1 | Beginner GR Stress-Energy Tensor Symmetry
In summary: From the definition of the stress-energy tensor, the first term is symmetric because ##S^{\mu \nu} \equiv F^{\mu \alpha} {F^{\nu}}_{\alpha} = {F^{\mu}}_{\alpha} F^{\nu \alpha} = F^{\nu \alpha}{F^{\mu}}_{\alpha}## .
Mike Karr
TL;DR Summary
It seems that the stress-energy tensor is both symmetric and non-symmetric.
I am a beginner in GR, working my through Gravitation by the above authors. If there is a better place to ask this question, please let me know.
I understand (from section 5.7) that the stress-energy tensor is symmetric, and from equation 5.23 (p. 141), it is explicitly symmetric. But evaluating equation 5.22 in a Lorentz coordinate frame, the last term is clearly symmetric, but the first term involves ##F^{\nu}_{\alpha}##, which is non-symmetric, at least according to equation 5.3 (p. 73). In particular, it is symmetric in the 0th column and row and anti-symmetric in the rest of the matrix. Multiplied by the anti-symmetric ##F^{\mu\alpha}## does not help the situation. So I can't get from 5.22 to 5.23.
I suppose my problem is understanding "in a Lorentz frame", but I thought all definitions of F and ##\nu## *are* in a Lorentz frame. Where am I going wrong?
The first term is symmetric for the simple reason that ##S^{\mu \nu} \equiv F^{\mu \alpha} {F^{\nu}}_{\alpha} = {F^{\mu}}_{\alpha} F^{\nu \alpha} = F^{\nu \alpha}{F^{\mu}}_{\alpha} = S^{\nu \mu}##.
Likes vanhees71
Mike Karr said:
Summary:: It seems that the stress-energy tensor is both symmetric and non-symmetric.
Multiplied by the anti-symmetric $F^{\mu\alpha}$ does not help the situation.
As @ergospherical showed, yes it does. The index ##\alpha## is not a free index and you therefore cannot consider if the expression is symmetric under exchange ##\mu \leftrightarrow \alpha## because doing so does not make any sense.
Likes vanhees71
Of course. Sorry to bother you with something so trivial.
ergospherical said:
The first term is symmetric for the simple reason that ##S^{\mu \nu} \equiv F^{\mu \alpha} {F^{\nu}}_{\alpha} = {F^{\mu}}_{\alpha} F^{\nu \alpha}##
For the last term above I found ##F^{\mu \alpha} {F^{\nu}}_{\alpha} = {F^{\mu}}_{\gamma} \eta^{\alpha \gamma} {F^{\nu}}_{\alpha} = {F^{\mu}}_{\gamma} F^{\nu \gamma}## , then renaming the dummy index ##\gamma \leftrightarrow \alpha## we get
$$S^{\mu \nu} = {F^{\mu}}_{\alpha} F^{\nu \alpha} = F^{\nu \alpha}{F^{\mu}}_{\alpha} = S^{\nu \mu}$$
Btw, just from a formal point of view, is it required to switch the indexes of the metric tensor ##\eta^{\alpha \gamma}## in order to raise the ##\alpha## index of ##{F^{\nu}}_{\alpha}## turning it into ##F^{\nu \gamma}## ? Thank you.
cianfa72 said:
Btw, just from a formal point of view, is it required to switch the indexes of the metric tensor ηαγ in order to raise the α index of Fνα turning it in Fνγ ?
That is kind of a moot point since the metric is symmetric by definition. Most people will do this without blinking.
yes of course, however from what you said the process of raising or lowering a tensor index by the metric tensor formally seems to require that.
What does "switch the indexes" even mean? The labels you put on the indexes are arbitrary.
If you see for example here https://en.wikipedia.org/wiki/Raising_and_lowering_indices the process of raising or lowering a tensor index involves as dummy/summing index the second index of the metric tensor.
Said that, from a practical point of view since the metric tensor is symmetric, there is actually no business to switch the indexes as in the above #5.
It's irrelevant for tensors over a real vector space. You do have to worry about the order with spinorial tensors, whose indices are by convention lowered by contracting over the left index of ##\epsilon_{AB}## and vice versa, e.g. ##v_A = \epsilon_{BA} v^B = - \epsilon_{AB} v^B##. (One consequence of this is that swapping the heights of a pair of contracted indices introduces a minus sign, ##u_A v^A = - u^A v_A##).
Likes dextercioby
As I said in #9 there is no problem at all ! As @ergospherical clarified for tensors over real vector spaces it is actually irrelevant.
Sorry, I got unconfused too quickly. I don't get the correct answer for ## T^{00} ##. Let's look at the two terms of equation 5.22. The last one is simple, I think:
## - \frac{1}{4} \eta^{\mu\nu} F_{\alpha\beta} F^{\alpha\beta}
= - \frac{1}{4} \eta^{\mu\nu} 2(E_x^2 + E_y^2 + E_z^2 + B_x^2 + B_y^2 + B_z^2)
= - \frac{1}{2} \eta^{\mu\nu} (E^2 + B^2) ##
Let's look at the ## \mu = 0 = \nu ## of the first term. The ## \alpha ##'s (second index) run across the rows of the matrices on pp. 73-74, so:
## F^{0\alpha} F^0_\alpha = (0, -E_x, -E_y, -E_z) \cdot (0, E_x, E_y, E_z)
= - E_x^2 - E_y^2 - E_z^2 = - E^2 ##
Since ## \eta^{00} = -1 ## (p. 53), the sum of these two terms is ## \frac{1}{2} ( - E^2 + B^2) ##, so dividing by ## 4 \pi ## gives:
## \frac{1}{8 \pi} ( - E^2 + B^2) ##
But the answer given by Ex. 5.1 is:
## \frac{1}{8 \pi} (E^2 + B^2) ##
What am I doing wrong?
In a local Lorentz frame ##\eta = \mathrm{diag}(-1,\mathbf{I})## so\begin{align*}
4\pi T^{00} &= F^{0\alpha} {F^0}_{\alpha} + \frac{1}{4} F_{\alpha \beta} F^{\alpha \beta}
\end{align*}Recall that ##E_i = F_{0i}## and ##B_i = -(1/2) \epsilon_{ijk} F^{jk}##. That means ##F^{0\alpha} {F^0}_{\alpha} = E^i E_i = E^2## and also \begin{align*}
F_{\alpha \beta} F^{\alpha \beta} &= 2F_{0i} F^{0i} + F_{ij} F^{ij} \\
&= -2E_i E^i + (\epsilon_{ijk} B^k)(\epsilon_{ijl} B_l)
\end{align*}Use the epsilon-delta identity: ##\epsilon_{ijk} \epsilon_{ijl} = \delta_{jj} \delta_{kl} - \delta_{jl} \delta_{kj} = 2\delta_{kl}##. Then\begin{align*}
F_{\alpha \beta} F^{\alpha \beta} &= -2E^2 + 2B^k B_l \delta_{kl} = 2(-E^2 + B^2)
\end{align*}Overall: ##4\pi T^{00} = E^2 + \frac{1}{2}(-E^2 + B^2) = \frac{1}{2}(E^2 + B^2)##.
ergospherical, thanks for your answer. What I was doing wrong was using the wrong components in ##F^{\alpha\beta} ##---I swapped the 0th row and 0th column. But your answer is much more clever, using formulas for ##E_i## and especially for ##B_i## that I would never have thought of. Also, I did not know of the epsilon-delta identity. Is it in MTW? Again, thanks for the help.
not sure, but the general formula is a fiddly determinant: https://en.wikipedia.org/wiki/Levi-Civita_symbol#Product
the most useful version to memorise is a single contracted index ##\epsilon_{ijk} \epsilon_{ilm} = \delta_{jl} \delta_{km} - \delta_{jm} \delta_{kl}## (mnemonic: something like "product of same positions minus product of opposite positions")
Related to MTW Gravitation: Exercise 5.1 | Beginner GR Stress-Energy Tensor Symmetry
1. What is MTW Gravitation?
MTW Gravitation is a textbook written by Charles Misner, Kip Thorne, and John Wheeler that covers the mathematical and physical foundations of general relativity.
2. What is Exercise 5.1 in MTW Gravitation?
Exercise 5.1 is a beginner-level exercise in MTW Gravitation that focuses on understanding the symmetry of the stress-energy tensor in general relativity.
3. What is the stress-energy tensor in general relativity?
The stress-energy tensor is a mathematical object that describes the distribution of energy and momentum in a given region of spacetime in general relativity.
4. What is the significance of the symmetry of the stress-energy tensor?
The symmetry of the stress-energy tensor is significant because it reflects the fundamental physical principle of conservation of energy and momentum in general relativity.
5. How does Exercise 5.1 in MTW Gravitation help in understanding general relativity?
Exercise 5.1 in MTW Gravitation helps in understanding general relativity by providing a hands-on approach to visualizing and understanding the symmetry of the stress-energy tensor, which is a key concept in the theory.
  • Poll
  • Science and Math Textbooks
12K
