MHB Multi-value Function: What & Why
  • Thread starter Thread starter highmath
    Function
highmath
Why multi-valued function is a function?
You can always make a multi-valued function $f$ between sets $X$ and $Y$ single-valued by considering the associated function (in the narrow, traditional sense) that maps $X$ to the power set of $Y$.
In the context of set-valued analysis (which has many applications in e.g. microeconomics), the multi-valued functions are often called "correspondences". Some problems from the application domain can then be translated elegantly into questions about those correspondences. If you are interested, I can provide more references.
In other contexts, such as complex analysis, multi-valued functions often arise as inverses, and then one typically make a choice by convention and calls it the "principal value".
A sphere as topological manifold can be defined by gluing together the boundary of two disk. Basically one starts assigning each disk the subspace topology from ##\mathbb R^2## and then taking the quotient topology obtained by gluing their boundaries. Starting from the above definition of 2-sphere as topological manifold, shows that it is homeomorphic to the "embedded" sphere understood as subset of ##\mathbb R^3## in the subspace topology.
