Multivalued limit of (i + i/n)^n
  • Thread starter Thread starter forcefield
    Limit
The discussion centers on the multivalued limit of the expression (i + i/n)^n as n approaches infinity, which approaches four discrete values: e, ei, -e, and -ei when n is an integer. The conversation highlights the confusion around why ei does not equal this limit, noting that e^i is defined as the limit of (1 + i/n)^n. Participants suggest that replacing n with a real number x may clarify the concept, referring to a limit cycle in the complex plane. The mention of a limit cycle indicates a circular behavior in the complex values involved. Overall, the discussion seeks to understand the nature of these limits and their definitions in complex analysis.
forcefield
I realized that (i + i/n)n approaches 4 discrete values (e, ei, -e and -ei) as n approaches infinity (if n is integer). (If I take that i2 = 1, then it approaches two discrete values (e and ei)). Does this kind of "multivalued limit" have some other name so I can learn more about it or where it has been applied ?
Why is ei not equal to this limit (since e1 is equal to the limit (1 + 1/n)n as n approaches inifinity) ? I know it's a matter of definitions but why isn't it defined this way ?
Thanks
Mathematics news on Phys.org
Hi ff,
"approaches 4 discrete values" is a little bit self-contradictory. Perhaps it's more sensible in this case to replace n by x (x a real number) and speak of a limit cycle (the circle ##|{\bf z}| = 1##) in the complex plane
"Why is ei not equal to this limit (since e1 is equal to the limit (1 + 1/n)n as n approaches inifinity) ?"
That is because ##e^i = \lim \,({\bf 1}+i/n)^n\ \ \ ## :smile:
Hi BU,
Thanks for the "cycle". I think you meant ##|{\bf z}| = e## in this case though.
I certainly do :smile: ! Sorry for the mistake.
Likes forcefield
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
