Multivariable Calc Image-Graph Problem
  • Thread starter Thread starter Loppyfoot
    Multivariable
The discussion revolves around converting a parametric curve defined by the function f(t) = (t, t^2 - cos(t)) into a graph representation in R3. Participants clarify that the graph can be expressed as F(t) = (t, t, t^2 - cos(t)). For the second part, they discuss finding a function h such that its level set for k=0 corresponds to the same curve, leading to the equation (t, t^2 - cos(t)) = 0. There is confusion about how to derive an implicit equation from the level set, with participants suggesting that the first step involves solving for t. The conversation highlights the challenges of visualizing and transforming parametric equations into different mathematical forms.
Loppyfoot
Multivariable Calc Image-Graph Problem!
Given a function f: R-R2 , by f(t) = (t, t^2 - cos(t)), which represents a curve in the xy plane parametrically, give a function whose GRAPH represents this same curve.
2) Also, give a function h whose level set for height k=0 represents this same curve.
From what I know, the graph of this function would be in R3. How would I make a function of a graph from that function? I'm probably missing an easy point but haven't picked up on it yet.
For number 2, I'm pretty confused on where to begin this problem.
Any thoughts?
Thanks a ton!
Yes, the graph of F:t-> (x(t), y(t)) is (t, x(t), y(t)). Just put in the x(t) and y(t) you are given.
For 2 you want a function z= F(x, y) such that F(t, t^2- cos(t))= 0 for all t.
Ok Thank you HallsofIvy.
So for another example for number one would be:
If I have f(u,v) from R2-R3, = (u^2+v,u+v,u+v^2),
The graph of this function would be: (u,v, U^2+v,u+v, u+v^2).
Great, I understand now! Thanks a lot sir.
So the equation would be f(t)= (t,t,t^2-cos(t)), correct? Just making sure...
I'm having trouble with number 2.
So I understand that for level sets, I look at the outputs and set them equal to some k.
In my case, k=0.
So, (t,t^2-cos(t))= 0.
Should the first step be to solve for t?
If so, how would I create an implicit equation from this problem? Thanks!
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 19 ·
  • · Replies 19 ·
9K
