Multivariable calculus -critical points
1 reply · 10K views · last reply
ultima9999
A rectangular box is to have a volume of [tex]96m^3[/tex]. The 4 sides and the top are to be made of a material of density [tex]1kg/m^2[/tex] and the flat base is to have a density of [tex]2kg/m^2[/tex]. Suppose that the base is of size x meters by y meters.
It was found in the first question that the mass, M in kg of the box is:
[tex]M(x,y) = 3xy + \frac{192}{x} + \frac{192}{y}[/tex]
Find the dimensions of the box so that the total mass of the box is a minimum.
So, I just find the critical points, which occur at [tex]f_x = f_y = 0[/tex]
[tex]f_x = 3y - \frac{192}{x^2} = 0[tex] [tex]y = \frac{64}{x^2}[/tex]<br /> <br /> [tex]f_y = 3x - \frac{192}{y^2} = 0[/tex]<br /> [tex]x(x^3 - 1) = 0,\ \ x = 0,\ 1[/tex]<br /> <br /> So critical points occur at (1, 64) and x = 0. We cannot have a dimension of 0, so minimum mass at x = 1, y = 64. The next question asks to prove that the dimensions found correspond to a minimum value of M(x,y).<br /> <br /> So I use second derivatives and the Hessian matrix.<br /> [tex]f_{xx} = \frac{384}{x^3},\ \ f_{xy} = 3,\ \ f_{yy} = \frac{384}{y^3}[/tex]<br /> [tex]\mbox{det(H)} = \frac{384^2}{(xy)^3} - 9[/tex]<br /> At (1, 64), det(H) < 0 which means that it is a saddle point, not a minimum. So, where have I gone wrong, or is the answer simply "there is no minimum"?[/tex][/tex]
a little help, too much perhaps
Your critical points aren't right: notice how m(x,y)=m(y,x) so that any critical points will have x=y? well, anyhow up to here it is ok:
[tex]y=\frac{64}{x^2}, x=\frac{64}{y^2}[/tex]​
now assume [tex]x\neq 0,y\neq 0[/tex] (because of just what you said: can't have 0 volume), now simplify them to get
[tex]x^2y=64, xy^2=64[/tex]​
multiply the first equation by y and the second by x to get
[tex]x^2y^2=64y, x^2y^2=64x[/tex]​
since both equations have one side equal to [tex]x^2y^2[/tex] we can set them equal to each other as in [tex]64y=64x[/tex] so x=y, plug this into any previous equation, say [tex]x^2y=64[/tex] to get [tex]x^3=64[/tex] so x=4, but x=y hence x=y=4 is the critical point.
