Multivariable calculus equation of a plane
The discussion centers on the interpretation of the variable "d" in the multivariable calculus equation of a plane, specifically in the form ax + by + cz = d. It is established that "d" does not have a fixed meaning on its own; rather, it represents a scaling factor that influences the position of the plane in relation to the origin. The distance from the origin to the plane can be calculated using the formula |d| / √(a² + b² + c²), which provides a definitive geometric interpretation of "d" in the context of the plane's orientation in \mathbb{R}³.
  • Understanding of multivariable calculus concepts, specifically planes in \mathbb{R}³.
  • Familiarity with vector notation and operations.
  • Knowledge of distance formulas in Euclidean space.
  • Basic algebraic manipulation skills.
  • Study the derivation of the distance from a point to a plane in multivariable calculus.
  • Learn how to parameterize planes using vectors in \mathbb{R}³.
  • Explore the geometric interpretation of coefficients in the plane equation ax + by + cz = d.
  • Investigate the implications of scaling the plane equation by a constant factor.
Students and professionals in mathematics, physics, and engineering who are working with multivariable calculus and need a deeper understanding of the geometric properties of planes in three-dimensional space.
iScience
equation of the form
ax+bx+cx=a0+b0+c0
ax+bx+cx=d
what exactly does "d" represent? is it the distance of a point from the plane? or is it the shifting of the plane along the normal vector of the plane?
and how does "d" represent that again?
A way to write an equation for a plane in \mathbb{R}^3 is
\vec{w} \cdot \vec{r} = dand the plane contains the point d\frac{ \vec{w}}{\left\|\vec{w}\right\|^2} You can check that the above is true. Now if \vec{u} and \vec{v} are parallel to the plane and one is not a scalar multiple of the other, then we could write the plane as \vec{r}(s,t) = d\frac{ \vec{w}}{\left\|\vec{w}\right\|^2} + s\vec{u} + t\vec{v} since we can always parameterize the plane as a point on the plane plus scalar multiples of two spanning vectors added on.
So you could think that the plane has been shifted by d\frac{ \vec{w}}{\left\|\vec{w}\right\|^2}, which is along the normal. It is somewhat ambiguous perhaps because some other shifts in other directions would result in the same plane.
The above applies to planes in \mathbb{R}^3.
ax+bx+cx=a0+b0+c0
ax+bx+cx=d
I guess you mean ##ax + by + cz = d##, not what you wrote. In that case the quantity$$\frac{|d|}{\sqrt{a^2+b^2+c^2}}$$gives the distance of the plane from the origin.
Also, if x= y= 0 then cz= d so z= d/c, if x= z= 0 then by= d so y= d/b, and if y= z= 0 then ax= d so x= d/a. That is, (d/a, 0, 0), (0, d/b, 0), and (0, 0, d/c) are the x, y, and z intercepts of the plane.
yes that's what i meant, could you show me how this yields the distance of the plane from the origin?
what does d itself represent?
Look in your calculus book how to calculate the distance from a plane to a point and use it to calculate the distance to (0,0,0).
##d## by itself doesn't have any particular meaning. If you multiply the equation through by ##2## you will have the same plane but now ##2d## on the right side. So ##d## in relation to the coefficients is what is significant. And the formula above gives geometric meaning to it.
