Multivariable factor decomposition
epkid08
(Keep in mind, I made this off the top of my head, so if something cancels easy, ignore it)
Let's say I had this expression:
f(x,y)=\frac{y^2-xy+1}{(x+y)(x-y)}
I want to decompose this to:
\frac{A}{x+y} + \frac{B}{x-y}
So i begin the process:
y^2-xy+1=A(x-y) + B(x+y)
y^2-xy+1=x(A+B) + y(B-A)At this point, I can't just plug in random numbers, I need to plug in points that correspond to this point:
(\frac{\partial f}{\partial x}, \frac{\partial f}{\partial y})
So I would pick a point, say (1,1), plug it into \frac{\partial f}{\partial x} to get the x coordinate of a point, P_1, then I would plug in the same point, (1,1), into \frac{\partial f}{\partial y} to get the y coordinate of the P_1. After I get two points,P_1 and P_2, I can plug them into the equation and solve the system to find A and B.
My question is, is this the right process to decompose the fraction, or am I way off?
At this point you see a problem. There does not exist such numbers A and B that the last equation would be true for all x and y. It follows that your decomposition attempt doesn't work.
What points are you talking about?
I did not understand your process, but since the task you are trying to do is impossible, I might guess your process was not right.
Why are you messing with partials? Let x = y in the first expression and you get
x^2 - x^2 + 1 = 2Bx \Rightarrow B = \frac{1}{2x}
Similarly let x = -y and you get
x^2 + x^2 + 1 = 2Ax \Rightarrow A = x^{2} + \frac{1}{2}
