Can Multivariable Interpolation Relate Three Sets of Data Points?
Multivariable interpolation can establish a relationship between three sets of data points (x, y, z) by constructing a polynomial function that fits the given points. A polynomial of degree three can be derived from the data, allowing for the calculation of z values based on x and y inputs. While the method guarantees interpolation at the specified points, the behavior of the function between these points may be unpredictable. Some users suggest exploring integral transforms in multi-dimensional spaces as an alternative approach. Overall, it is possible to create a function that meets the requirements, and there are methods available that do not require extensive mathematical knowledge.
KV-1
Hello!
I am wondering if it is possible to establish a relationship between three sets of points (x,y,z) by interpolating.
Basically i need a function that takes x and y and gives me a z that matches the following points:
130 472 5
130 590 6
130 738 7.5
130 944 10
155 563 5
155 704 6
155 880 7.5
155 1126 10
180 654 5
180 817 6
180 1022 7.5
180 1308 10
205 745 5
205 931 6
205 1163 7.5
205 1489 10
240 872 5
240 1472 8
I want the middle column to be yielded by the equation when the outer columns are fed into it.. ex (first point): f(130,5) = 472
is this possible? if so, are there any calculators that you recommend or methods that don't require very complex math? (I only know calculus).
thanks!
Mathematics news on Phys.org
Well, let's say you had a function that is just from R to R. That is, it takes in one variable and spits out a number. If you had n points at which you knew the value of the function, then you can construct an n-1 degree polynomial that will pass through each of those points, and this polynomial is unique. Now, you have what looks to be 4 x values and 4 y values. Now, you should be able to construct a polynomial in the two variables x,y that is of degree 3. That is, it has the form: p(x,y) = a_{3,3}x^3y^3 + \cdots + a_{3,0}x^3 + a_{2,3}x^2y^3 + \cdots a_{2,0}x^2 + \cdots a_{0,3}y^3 + \cdots a_{0,0}, where you can find the values of the coeficitnts a_{i,j} by solving a system of 16 equations (using the 16 data points you have.) Now, I can show you how to set this up, but I am not sure how well something like this will interpolate. I know that it will interpolate exactly to each of you data points, but I don't know enough theory to be able to predict how it will behave in between those points.
Oh thanks!
Not sure though, I think I found some equations that give me the desired points without having to interpolate though...
It helps to know how this can be done though!
Hey KV-1 and welcome to the forums.
Are you aware of integral transforms, especially on multi-dimensional spaces?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
