btb4198 said:
and I can't hear
60Hz nor 82.407Hz
is that normal ?
Hi btb, i am also a musician and was curious to see what you were writing about.
Hearing the audio spectrum varies with each individual. It can deteriorate depending on the
intensity of sounds you have been exposed to throughout your life and also the high end tends to
deteriorate with age.
That being said, i just tried the 60 and 82.407Hz signals this frequency generator made and i can hear both tones. It sounds like the intensity (volume) is attenuating with pitch (frequency), such that a 100Hz tone sounds louder to me than the 82.407Hz which sounds louder than 60Hz.
My suggested experiment: make sure you are using headphones of some kind. I am only using inexpensive earbuds. Set the volume on your computer to low (so as not to damage your ears). Try to find the lowest frequency you can hear with this tone generator. As you continue to generate lower pitches, you may find you need to step up the volume to hear them.
On your referenced site hearing test page, they recommend you sit in a "quiet room" and use "good quality headphones". So if you use that criteria, you can optimize the results of my suggested experiment. However, for comparison, in my environment, there is ambient noise (fan inside my laptop) and i am using cheap earphones.
btb4198 said:
the highest note on a piano is B8 is 7902hz
can a human sing that?
Yes, however I suspect you meant to compare to
C8 (4186Hz) the highest note on a standard 88-key piano.
Adam Lopez has vocalized a pitch as high as
C♯8 (4434.92Hz), a semitone above C8.
