Must all equal values be in the same quartile
  • Thread starter Thread starter alexbib
Equal values do not need to be in the same quartile, as this can lead to unequal groups. When dividing a number of values that isn't divisible by four, such as ten, quartiles can be approximated, resulting in groups like 3-2-3-2 or 2-3-3-2. For percentiles with fewer than 100 values, similar approximations apply, as exact calculations require a larger dataset. Small sample sizes may not exhibit normal distribution behavior, making it essential to avoid preconceived notions about data distribution. Using software for binning is recommended to minimize bias, although manual methods can still be applied for educational purposes.
alexbib
Posted this in the stats section, but nobody seems to be reading that section...
I have a few questions about distributing values into quartiles:
1.must all equal values be in the same quartile, even if that makes you create (sometimes very)unequal groups?
2.what do you do when your number of values cannot be divided by 4? Say I have 10 values, do I make the quartiles 3-2-3-2, 2-3-3-2, or something else?
About percentiles, what do you do when you have less than 100 values?
I know stats isn't meant to be used on small numbers of values, but I am tutoring two high school students and couldn't answer these questions.
Thanks,
Alex
Mathematics news on Phys.org
I believe you are trying to make a mountain out of a mohill. Specifically, to have EXACT quartiles, the number of samples has to divisible by 4, similiarly for percentiles, divisible by 100. Otherwise you are stuck with approximations.
In addition to what mathman said, you shouldn't try to make your quartile "look like" some preconceived idea. For small samples, you can't expect to see any normal curve behavior. And perhaps your data doesn't fall on a normal curve anyway. Best to use software to do your binning to avoid operator bias.
Unfortunately, I cannot use software. I have these questions because I am tutoring high school students who have written tests about dividing small samples into quartiles.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
