Mutual effects of gravity and velocity on time
Dmstifik8ion
The Earth takes the shape of an oblate spheroid due to its rotation and so gravity is stronger at the North/South Poles while the Equator has a velocity relative to the Poles.
When we consider General Relativity (the effect of gravity on the passage of time) together with Special Relativity (the effect of velocity on the passage of time) do these effects precisely cancel out maintaining synchronicity of clocks over the surface of a rotating oblate spheroid?
Dmstifik8ion said:
The Earth takes the shape of an oblate spheroid due to its rotation and so gravity is stronger at the North/South Poles...
Don't be so quick to assume that gravity is greater at the poles because of the smaller radius. I believe this is false.
Basically, the answer is yes. All clocks on the geoid run at the same rate. See for instance http://www.physicstoday.org/vol-58/iss-9/p12.html or http://hermes.aei.mpg.de/2003/1/article.xhtml (it's a long article, see the section above (21)).
This ignores tidal forces from the sun and moon, which have only a very small effect. (The effect does perturb the theoretical ideal, i.e. it hasn't been included in the above analysis).
One can derive this if one assumes that energy is conserved. The geoid is defined to be an equipotential surface in the rotating frame. Therfore, if energy is conserved, light measured in the rotating frame should have the same energy if it starts and stops at any two equipotential points, i.e. there should be no net red or blueshift between any two points on the geoid.
Energy conservation in GR can get tricky, but as long as one sticks to static geometries this argument works fine.
Thanks, the links are perfect!
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
