axim
- Messages
- 23
- Reaction score
- 12
- TL;DR
- In a transformer, the secondary coil length is changed but the number of windings stays constant (inductance of secondary changes). Flux created by primary stays the same (open load), why does the secondary voltage change?
Hello!
I have a question regarding the mutual inductance of two coils in a transformer.
In the formulas for linked coils ##M=k*\sqrt{(L_1*L_2)}## where ##k=1## for a perfect coupling.
I wanted to check my understanding about mutual inductance and see how it can be determined. When I vary the secondary coil length I'm getting into trouble.
My approach:
To determine the mutual inductance, I found many examples where one coil ##L_2## of length ##l_2## with ##N_2## windings (I refer to it as output) is surrounded by a coil ##L_1## of length ##l_1## with ##N_1## windings (input). The radius is ##r##.
With the assumption that length ##l_1>=l_2## and ##l >>r## the simplification is done that the flux from ##L_1## will be nearly constant inside the solenoid and pass completely through ##L_2##. The surface area entering the coils should be ##A## and is equal (they have basically the same radius). This example seems to be similar to a transformer (flux created by a current flowing through ##L_1## is guided completely through ##L_2## and will induce a voltage here). No current flow in ##L_2##, open load.
Can I use this approach here? For better understand I put a sketch below.
Because of ##l>>r## the flux generated inside ##L_1## is ##μ*N_1*I_1/l_1##. As it passes through ##L_2## completely it causes the mutual induction ##M_{21}=μ*N_2*N_1*A*/l_1##. This is valid for any length ##l_2## as long as it is shorter than ##l_1##.
##L_1## and ##L_2## have same length:
In case ##l=l_1=l_2##, the inductance values are: ##L_1=μ*N_1^2*A/l## and## L_2=μ*N_2^2*A/l.## I see that ##M_{21}=\sqrt{(L_1*L_2)}##, same as in the transformer formula, good.
If ##N_1=2*N_2## then ##L_1=4*L_2##, that matches a regular 2:1 transformer operation:
The input voltage will cause a magnetizing current (input divided by impedance of ##L_1##), which will cause the self inductance of ##L_1## with the same voltage opposed to the input. The induced output at ##L_2## will be half of the input voltage (As ##N_2*N_1## from ##M_{21}## divided by ##N_1^2## from ##L_1## substituted = ##0.5*N_1^2/N_1^2 = 0.5## and I know ##L_1## counteracted the input voltage). The output is open so no current can flow in ##L_2##.
Or in shorter words: ##M_{21}## is ##0.5*L_1## and both see the same flux.
##L_2## made shorter (my problem starts here):
Now, lets assume the coil ##L_2## is made shorter, but still keeps the same amount of windings as before. It is now basically the input coil ##L_1## cut in half, so it only has the length ##l_2=l_1/2##. If the windings are kept the same and the length is now halved, the inductance has doubled (same ##N_2## but half length).
As ##L_2## is still completely within ##L_1## (even more now with the half length), the flux it sees from ##L_1## is still the same (entry/exit fringes neglected), and it passes through the same amount of windings. ##M_{21}=μ*N_2*N_1*A*/l_1## - no change to the equation above, same flux and same number of windings. Now ##L_1=2*L_2## instead of ##4*L_2## as the ##N_2/l_2## part of the ##L_2## inductance has changed.
But, according to the formula, the mutual inductance will stay the same.
This means: The input voltage at ##L_1## will still create the same magnetizing current and self inductance as before (no change here). As the mutual inductance stays the same, also the same voltage should be induced at ##L_2## (same number of windings as before).
Now here I have a discrepancy.
##L_1## has stayed the same, it will have the same magnetizing current and according to my understanding create the same flux in the circuit. The inductance of ##L_2## has changed but not its windings.
Now with ##l_2=l_1/2## there is a discrepancy: ##M_{21} != \sqrt{(L1*L2)}##
##\sqrt{(L_1*L_2)} = \frac{μ*N_1*N_2*A} {0.707*l_1}##
Now because of the changed length the output is ##\sqrt{2}## higher, which does not match my own derivation where the mutual inductance stayed the same.
If I simulate in Spice and link two coils ##L_1## and ##L_2## where ##L_1=2*L_2## with ##k=1##, without load for ##1V## input I get ##0.707V## output, which matches the equation ##M=\sqrt{(L_1*L_2)}##. When following the scheme described above it should be ##0.5V## only.
Where is the mistake?
Summarized: The flux created at ##L_1## is always the same and should pass completely through ##L_2## so I expect it will always see the same flux. If the number of windings in ##L_2## stays the same according to my derivation above the induced output voltage should be the same. But as the inductane of ##L_2## is different the voltage is different, matching ##\sqrt{(L_1*L_2)}##. If the voltage induced is number of windings multiplied with the flux change ##e=N*\frac{dΦ}{dt}##, and neither windings nor flux have changed at ##L_2##, why is the induced voltage seen different?
Some help to clear this up would be appreciated a lot!
My approach:
