My weight cancels out the normal force from the floor
When standing and leaning against a wall, two main forces act on a person: the normal force from the ground counteracts gravity, while friction prevents slipping. The force exerted by the wall is balanced by the horizontal frictional force at the feet, ensuring stability. The vertical component of the forces includes gravity acting downward and the normal force acting upward. Additionally, while the vertical friction force at the wall is typically disregarded, it can play a role in preventing sliding. Understanding these forces is crucial for analyzing equilibrium in this scenario.
PhysKid24
If I'm standing on the ground and at the same time leaning on a wall, what are the forces acting on me? My weight cancels out the normal force from the floor, but what cancels out the force exerted on me by the wall, say horizontally, so as to make the sum of the forces 0? Thanks.
In your feet you have two reaction forces. One normal force because you are standing on the ground (due to gravity) and one that is directed horizontally in the opposite direction (towards the origin of the reference frame if you will) because of friction between your shoes and the ground. Otherwise, you would fall over. Then in your center of mass you have gravity working in onto you. At the point where you touch the wall you will have two reactionforces again. One horizontal (otherwise you would breake the wall and fall through it) and one force pointed upwards due to friction. Otherwise you would slide down...
regards
marlon
Normally the vertical friction force at the wall is disregarded...
marlon, just as an addendum
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
