N-D spring-mass damper total energy
1 reply · 7K views
ashapi
I am trying to derive the total energy for an n-dimensional linear (Hookeian) spring-mass damper system and show that the total energy is either decreasing or constant.
1D spring-mass damper equation
n-D spring-mass damper equation
I started with the following force equation in 1D to describe the system:
(1) m[tex]\ddot{x}[/tex] + b[tex]\dot{x}[/tex] + kx = 0
Where:
m[tex]\ddot{x}[/tex] = Facc = m[itex]\frac{d^{2}x}{dt^{2}}[/itex]
b[tex]\dot{x}[/tex] = Fdamp (viscous friction) = C[itex]\frac{dx}{dt}[/itex]
kx = Fpotential (gradient of some potential) = [tex]\nabla[/tex]P(x)
So the equation becomes:
(2) -[tex]\nabla[/tex]P(x) - C[itex]\frac{dx}{dt}[/itex] = m[itex]\frac{d^{2}x}{dt^{2}}[/itex]
I then modeled the total energy as follows:
(3) Etot = P(x) + [itex]\frac{1}{2}[/itex]m[tex]\dot{x}[/tex]2
and
(4) [itex]\frac{dE}{dt}[/itex]= [tex]\nabla[/tex]P(x)[tex]\dot{x}[/tex] + m[tex]\dot{x}[/tex][tex]\ddot{x}[/tex]
In (4) I substituted m[tex]\ddot{x}[/tex] from (1) and got:
[itex]\frac{dE}{dt}[/itex]= [tex]\nabla[/tex]P(x)[tex]\dot{x}[/tex] + [tex]\dot{x}[/tex](-[tex]\nabla[/tex]P(x) - C[tex]\dot{x}[/tex])
=> -C[tex]\dot{x}[/tex]2
...which shows that total energy is either decreasing (|[tex]\dot{x}[/tex]| > 0) or constant ([tex]\dot{x}[/tex] = 0)
I then tried to derive the total energy for the n-dimensional case and relate it to an n-D force equation as I did above. To do this I looked at the 2D case and then generalized the formulas for kinetic and potential energy to n-D but I'm not sure if this was correct. Here are my kinetic and potential energy equations for 2D:
My latex seems to bug out sometimes so if it looks weird please click on the source but let me continue...
KEtot,2D = [itex]\frac{1}{2}[/itex](m11[tex]\dot{x}[/tex]12 + m22[tex]\dot{x}[/tex]22 + m12[tex]\dot{x}[/tex]1[tex]\dot{x}[/tex]2)PEtot = [itex]\frac{1}{2}[/itex](m11[tex]{x}[/tex]12 + m22[tex]{x}[/tex]22 + m12[tex]{x}[/tex]1[tex]{x}[/tex]2)
I took the generalized forms to be:
KEtot,nD = [itex]\sum_{i=1}^{n}[/itex] (mii)[tex]\dot{x}[/tex]i2 + [itex]\sum_{j=1}^{n-1}[/itex] [itex]\sum_{k=j+1}^n[/itex] (mjk)[tex]\dot{x}[/tex]j[tex]\dot{x}[/tex]k
...and the same for PE with [tex]{x}[/tex] replacing [tex]\dot{x}[/tex].
My plan was to take the derivatives of these and replace the m[tex]\ddot{x}[/tex] terms with the force equivalences (as above). Is this right? I also can't think of how to make a generalized form of the force equation for an n-D vector.
Any help would be greatly appreciated.
Thanks,
ashapi
