Can a 10 nm facet area achieve 10^12W/m^2 for laser heating on a tungsten tip?
  • Thread starter Thread starter Benindelft
    Heating Laser
The discussion focuses on heat calculations for a CW laser-illuminated tungsten tip used in photoemission, specifically examining how to optimize the tip geometry to increase flux without melting. The calculations indicate that a facet area of around 10 nm could theoretically allow for an application of 10^12 W/m^2, raising concerns about potential ablation of the tip. The participant questions the implications of using a laser wavelength significantly larger than the tip size, suggesting that this could affect the heating dynamics. They express uncertainty about the penetration depth of photons and its impact on such a small scale, alongside considerations of local electric field and plasmon enhancement. The discussion seeks additional insights on factors to consider in this context.
Benindelft
I am doing some basic heat calculations about a CW laser illuminated tungsten tip (which should be used for photoemission) - I started to play with the tip geometry to try and find a way to get more flux Watts/metre^2 onto the tip without it melting. I found that after solving the 1d heat equation for a cone and then including a rod on the other end (held at T=300K):
{dT=\frac{Q}{k*A(z)}dZ=\Dint{T_{facet}}{T_{shaft}}=\Dint{Z_{facet}}{Z_{shaft}} \frac{Q}{kz^{2}tan^{2}\theta\pi}dZ}
which comes out as
{Q=\frac{T_{facet}-300}{\frac{facetradius^{-1}-shaftradius{^-1}}{tan^{\theta\pi}k}+\frac{shaftlength}{shaftradius^2{\pi}k}}}
This assumes (wrongly of course) that all the laser power is absorbed on only the facet of the tip.
Now my calculations tell me that if I make the facet area around 10 nm i can apply 10^12W/m^2.
Is this possible? Am I not doing something that should ablate my tip immediatly ?
Science news on Phys.org
I might be completely on the wrong track, but - would it not cause problems if the object you want to heat is so much smaller than the wavelength of the light you are using ?
If it is visible light, we are talking of ca. 500nm, and let's say 1000nm if you use near infrared. So your object at 10nm is about 100 times smaller, have you considered this in your calculations ?
I don't have anything in the calculations, but I am pretty sure that we get quite a strong local electric field enhancement, that's all good (as long as it doesn't blow up the tip). There might also be some plasmon enhancement I think (but really not sure , I read that tungsten doesn't have a strong plasmon enhancement).
If there is an increase in the Power Density then that's not important (I can just supply less power initially to compensate). I am more worried about the penetration depth of the photons into the tip and what that means to the tip on such a small scale?
Can you suggest anything other things to consider?
Thread 'Thermo Hydrodynamic Effect'
Vídeo: The footage was filmed in real time. The rotor takes advantage of the thermal agitation of the water. The agitation is uniform, so the resultant is zero. When the aluminum cylinders containing frozen water are immersed in the water, about 30% of their surface is in contact with the water, and the rest is thermally insulated by styrofoam. This creates an imbalance in the agitation: the cold side of the water "shrinks," so that the hot side pushes the cylinders toward the cold...
