Natural frequencies of simplified tympanic membrane model
The discussion focuses on the analytical determination of natural frequencies of the tympanic membrane using a simplified model of a 2D sectorial annulus membrane. Participants explore the parameters and equations involved in the calculations, including the use of Bessel functions.
  • One participant presents their calculations for the natural frequencies of the tympanic membrane, noting a discrepancy between their result of 128Hz and an expected value of approximately 412Hz.
  • The participant questions whether their choice of parameters, particularly the tension of 35MPa, might be incorrect or if there are issues with units or dimensions in their equations.
  • Another participant seeks clarification on whether the model is for a tympani drumhead or the eardrum, indicating potential confusion about the application of the model.
  • Participants confirm that the model is indeed a simplified representation of the eardrum.
  • References to a specific paper are made, suggesting that some participants are following established research in their modeling approach.
There is no consensus on the accuracy of the calculated natural frequencies, as one participant expresses confusion over the results and parameters used. Multiple viewpoints regarding the modeling approach and the specific application of the model remain present.
Participants have not resolved the discrepancies in the calculated frequencies, and there are indications of potential issues with parameter choices and assumptions in the modeling process.
kravky
I am trying to anallytically determine natural frequencies ƒ of the tympanic membrane. I am using 2D sectorial annulus membrane as a simplified model of tympanic membrane according to following picture
The parameters that i want to use are following:
THICKNESS = 0,1 mm
The natural frequencies can be calculated from equation
where λmn can be calculated from
where Jn and Yn are Bessel functions of first kind and second kind.
I find out using MAT*AB for n=0 (zeroth order) that for m=1: λm0 = λ10=0,7484 (i used milimeters for R1 and R2)
After substituting λmn10=0,7484 into first equation for frequncy fmn i get the fundamental freq. f1=128Hz. However i am supposed to get f1=412Hz approximately. I don't know what am i doing worng. The parameters i chose are based on experiments from colleagues so i don't think they are wrong (although this tension 35MPa seems high to me)
My equations are derived using Newtons second law.
Maybe some units or dimensions in my equations are messed up?
I'm a little confused- are you modeling the drumhead for a tympani, or are you modeling the 'eardrum'?
I am modelling eardrum. Simplified eardrum
  • · Replies 18 ·
