Exploring Imaginary Dimensions & Time Motion
In summary, apparently, when one calculates a length in flat space-time, one must add the lengths in the three spatial dimensions, and subtract square root(-1)ct. My first question is why is this weird equilibrium exists between space and time where motion through space takes away from motion through time (aging, time passage... you know what I mean)? Furthermore, why subtract? Why is it that this weird equilibrium exists between space and time where motion through space takes away from motion through time (aging, time passage... you know what I mean)? Finally, why do we have this default time motion? The other dimensions don't work like this, it's not like
  • #36
Anonym said:
Who taught you that? If you will read A. Einstein original paper Ann. Phys., 17, 891, 1905 (Ch.1, Kinematical Part, par. 1-5) you will discover that A. Einstein was not less smart than you and did exactly what you consider the natural physical approach.
Einstein titled that paper "On the Electrodynamics of Moving Bodies"
In part one he defines simultaneity for stationary bodies... then in the very beginning of part 2 ("On the Relativity of Lengths and Times") before he even starts speaking about moving bodies he writes:
"The following reflexions are based on the principle of relativity and on the
principle of the constancy of the velocity of light."
it is more than obvious that he derived SR from the law of propagation, it is the whole foundation for Lorentz transformation... that a stationary body and a moving body should measure the same speed for light
I think you misunderstood me
  • #37
it is more than obvious that he derived SR from the law of propagation. I think you misunderstood me
No. You misunderstood him. The law of propagation is Maxwell equations. It is more than obvious that you confuse kinematics and dynamics. It is the standard “vanilla” way to formulate the theory. P.A.M. Dirac (for example) in “Principles of QM” did exactly the same (Ch.1-4 and the rest).
A.Einstein used word “light” instead of “signal” since it was the problem in front of his eyes. The solution ignited the next step: formulation of GR, theory of gravitational fields, which was done again in exactly the same “vanilla” way. In Classical physics we have only two types of signals.
SpitfireAce said:
It is the whole foundation for Lorentz transformation... that a stationary body and a moving body should measure the same speed for light.
This is the principle of relativity (N. Copernicus) mentioned above that have nothing to do with the equations of motion; however it must be consistent with them. Think why we consider the Galileo law of inertia independent from the Newton second law (dynamics)?
The principle of relativity is the definition of the inertial frames (does not a matter Galileo group or Lorentz). And it is additional Principal Physical Postulate.
Our debate is pointless. In your post #26 you described exactly what was done by A.Einstein.
Regards, Dany.
P.S. Notice, that you start your threat with asking whether somebody will explain physics to you. And now you are in position to explain physics to me. There is nothing wrong with that. I am glad that it is so.
  • #38
I was a tad frustrated, I'm sorry... I do appreciate your posts
I was trying to think of a good way to really explain special relativity to my dad... I am a firm believer that anything that is well understood can be expressed in a simple and very understandable way, and my dad doesn't know mathematics or physics (incidentally, either do I since I can't explain WHY it happens)...
when an observer clocks how long it takes a particle to go from a to b, the clock doesn't need to receive signals or information from the particle...
the particle and the clock run along independently of each other... the stationary observer connects them, he looks at the clock and looks at the particle and says that the hand on the clock moved this distance while the particle moved that distance between two simultaneous events (start and end of motion). But now for an observer moving towards the particle, the light carrying the information that the particle has started will reach him sooner than for a stationary observer, so the time that the hand on the clock started to move and the time that the particle started to move are no longer simultaneous (their finish times are no longer simultaneous either)... though they would look simultaneous since our perceptions don't take light travel time into account, thus under the assumption that the clock hand and particle started simultaneously (though they didn't), we see the effects of the unfair race as time dilation for the clock and length contraction for the particle.
*perhaps the time dilation in gravitational fields can be explained by a longer time delay caused by light having to travel through curved space-time to reach an observer in a gravitational field
I haven't thought this through completely (it seems that whether the obs. is moving towards the event or away should have an effect on whether time is dilated or contracted, but relative velocity between two objects moving apart is greater than rel. vel. if they are moving closer together so maybe the equations take this into account) but do you think its possible to describe time dilation and length contraction based on the principle of simultaneity (along the lines of reasoning above) or some similar logic or is it just something fundamental that one should just accept (like quantum wave collapse) that has nothing to do with the speed of the signal?
surely there must be some mechanism...
  • #39
Mentz114 said:
Thanks for pointing out that C2 and C4 are the Pauli and Dirac algebras. I once knew that!
Sure, but I didn’t want to enter into discussion of the external degrees of freedom vs internal degrees of freedom (electric charge; E.Majorana particles are neutral) and the interconnection between them. We discuss here SR/CED/QED only and nature of time in it.
However, it remained not clear why I call the introduction of i=sqrt(-1) “stupid”. I do not know who did that. Perhaps, L.Euler. The matter is in it location on the time axis of history of science and the connection with the Trace operation.
The trace operation is crucially important in group theory and classical physics. Notice that the definition of trace as the sum of diagonal matrix elements is “philosophy”. It is not a math. The math operation must be defined uniquely. Now, consider for example A=2x2 matrix with the pure imaginary diagonal elements. Then in general Tr(A) not =0. But if you write the same matrix as 4x4 with real matrix elements, then Tr(A)=0.
To the best of my knowledge this mathematical mistake was corrected only by J.Dieudonne. Nevertheless it is still very common in current physical and mathematical literature.
Regards, Dany.
  • #40
Mentz114 said:
SpitfireAce,
The reason why we subtract the time extension is that it works. In special relativity it turns out that quantity that is preserved in transformations of co-ordinates is the difference between the spatial extent and the temporal extent ( or interval). So in flat space
[tex]ds^2 = -c^2dt^2 + dx^2 + dy^2 + dz^2[/tex]
is invariant. Quantities that are invariant under transformations are important because they represent physical things rather than mathematical artefacts.
The reason why we subtract the time extension is that in special relativity, the speed of light is constant;
[tex] (dx^2 + dy^2 + dz^2) / dt^2 = c^2 [/tex] , and [tex]ds^2 = -c^2dt^2 + dx^2 + dy^2 + dz^2 = 0 [/tex] for light;
For all observers, it's a constant (zero) and is a special case of
[tex]ds^2 = -c^2dt^2 + dx^2 + dy^2 + dz^2[/tex] in general
  • #41
Sorry to butt in. I just hope I can help a bit.
I am not sure what situation you are considering here, exaclty. The clock is moving together with the particle (so the clock is in the frame of the particle)?
In any case, the start and end of the motion can *not* be simultaneous! In any frame. So I am not sure what you mean by "simultaneous".
Whenever an observation is made of a distant event (something happened over there and I have to wait to see the light from the event), there is some time delay, but the key point is that that time delay has nothing to do with all the strangeness of relativity. This is why it is important to introduce the notion of local observers. One must imagine an infinite number of observers located at every point in any given frame, with their clocks synchronized. One should really only talk about measurements made by local observers. This eliminates completely all effects of time delay due to the finite speed of propagation of light. When we talk about two events not being simultaneous in all frames, we do NOT talk about any effect due to the finite speed of light (which only make it seems AS IF two events are not simultaneous but it would not be a real effect).
[/quote]
surely there must be some mechanism...[/QUOTE]
Again, you seem to think of time delays as being only due to finite speed of propagation. Even in special relativity, this is not what we mean by saying that time is different in different frames.
I think understanding the notion of local observers is a very important point in understanding what special relativity is really saying. I know that when I teach the subject, I put a lot of emphasis on this in order to avoid any misunderstanding about difference in time between two frames being simply due to the time it takes to *observe* something for a non-local observer.
  • #42
SpitfireAce said:
Apparently, when one calculates a length in flat space-time, one must add the lengths in the three spatial dimensions, and subtract... square root(-1)ct,
If you don't like the minus sign in:
ds^2 = -dt^2 + dx^2 + dy^2 + dz^2
you can rearrange it to:
dt^2 = ds^2 + dx^2 + dy^2 + dz^2
Then you see that ds, which gives you the proper time for timelike curves, is "just like a space dimension". If you use it as a dimension in a diagram, then the length of the curve is the coordinate time dt :
http://www.adamtoons.de/physics/relativity.swf
  • #43
It should be further pointed out that the "interval" dt is not invariant. The invariance of ds as an interval is what makes the geometry possible.
Thinking of ds as a kind of space dimension can be instructive, however. One interesting question is: where is this spatial dimension when dx, dy and dz are zero, i.e., when the object is at rest? Is ds measuring a "hidden" dimension?
  • #44
SpitfireAce said:
furthermore, why subtract? why is it that this weird equilibrium exists between space and time where motion through space takes away from motion through time (aging, time passage... you know what I mean)?
Why do we have this default time motion? The other dimensions don't work like this, it's not like I move up at full speed, but when I move right or left, I move up slower... the components are separate, like in projectile problems
on a somewhat separate note, why do photons have paths in space-time if they don't move through time?
I love your questions. :D
If time is to be treated as a dimension through which we (and all other known particles and waves) move (admittedly not a spatial dimension), the apparent slowing down of clocks at relativistic speeds is not an effect of that clock slowing down in time, but of its speeding up. Which leads to the problem of clocks not measuring motion through the time-dimension. The faster you go in space, the faster you go in time. (Although obviously not at the same rate. As can be seen from Ek = (gamma - 1) * mc^2 (relativistic kinetic energy) to double a particle's rate of "motion" through time, you need energy equal to the rest-mass (mc^2) of said particle. This energy would obviously give far more than a doubling in speed through space. :)
Photons do move in time. It's just that if they had wristwatches, they wouldn't seem (to us) to be working. They move very, very fast in time indeed.
Not sure what you mean by a default time motion.
(First post for me. Bracing for impact.)
-Mnemosyne
  • #45
It depends how you define "moving in time". For me a clock is "moving in time" if it is ticking. In that sense photons do not "move in time", only in space. But that's just one possible definition: Clock changes postion = movement in space; Clock runs = movment in time.
  • #46
What would we do if we didn't have clocks?
