Need advice on capturing sound
  • Thread starter Thread starter baketrab
    Need advice Sound
To monitor the noise frequency of a mechanical object, an audio spectrum analyzer is recommended, with options available as smartphone apps for basic analysis. The concept involves capturing the "acoustic signature" of the object, which can indicate changes in its condition. Equipment like the Fluke 810 Vibration Analyzer is suggested for detailed monitoring, particularly in industrial settings. Additionally, infrared thermography can complement sound analysis by identifying temperature increases that signal potential failures. Exploring existing research and applications in acoustics can provide further insights into effective monitoring techniques.
baketrab
I am looking to find a way to monitor a mechanical objects noise frequency. The end result would be the ability to see when the sound changes.
Here's my thought process:
A mechanical object that is making repetitious movements, would generate a particular 'sound' or 'frequency' within a particular range, on a consistent basis. If that objects signature changes, that would indicate a change in the object creating the sound.
So what type of equipment could be purchased, made, designed to facilitate capturing the 'signature/sound/frequency' I am looking for?
I never got too involved with sounds/frequency so I'm not sure what terminology to use here either.
Any advice on where to look, what to look for, or even the proper terminology to use would be appreciated.
Thanks!
Thanks!
Welcome to the PF.
The keywords here are "audio spectrum analyzer"
http://en.wikipedia.org/wiki/Spectrum_analyzer
You can even get smartphone apps that will do basic audio spectrum analysis...
You may find it useful to research how others have already done (and are doing) what you're asking about. We can measure the "acoustic signature" of a submarine in such detail so as to identify the name and number of that particular submarine.
Here are two applications using acoustics to monitor mechanical/biological systems:
Spectral Analysis of Acoustic Vibrations on the Surface of the Human Body
http://www.zainea.com/humanvibrations.htm
Sound Recognition Lab (SRLab) is an interactive pattern-formation and pattern-recognition application for acoustics. It is made for engineers and researchers who deal with complex acoustic systems and/or large quantities of audio data in:
Industrial automation
Animal bioacoustics
Medical bioacoustics
Noise analysis
Phonetics and neuro-science
http://www.sejona.org/srlab.php
Not trying to sell anything but Fluke makes a Vibration Analyzer that does just about what you were asking.
It's called the Fluke 810, there are videos on youtube showing it in operation, we use it at my facility to monitor electric motor bearings for failure, very nice unit. Capable. Not cheap though.
http://www.fluke.com/fluke/usen/vibration/fluke-810.htm?PID=56137
Another predictive maintenance baseline procedure that also works is thermo recordings. Take a infra red camera record the working temperatures. Increase of those temperatures indicate failures such as bad bearings etc. This can also be used on circuit breakers, if the circuit is 10 degrees above the room temperature its an indication of too large an amperage draw on that ciurcuit. Wortks on electronics as well.
Hi all, I have a question. So from the derivation of the Isentropic process relationship PV^gamma = constant, there is a step dW = PdV, which can only be said for quasi-equilibrium (or reversible) processes. As such I believe PV^gamma = constant (and the family of equations) should not be applicable to just adiabatic processes? Ie, it should be applicable only for adiabatic + reversible = isentropic processes? However, I've seen couple of online notes/books, and...
Thread 'How can I find the cleanout for my building drain?'
I am a long distance truck driver, but I recently completed a plumbing program with Stratford Career Institute. In the chapter of my textbook Repairing DWV Systems, the author says that if there is a clog in the building drain, one can clear out the clog by using a snake augur or maybe some other type of tool into the cleanout for the building drain. The author said that the cleanout for the building drain is usually near the stack. I live in a duplex townhouse. Just out of curiosity, I...
I have an engine that uses a dry sump oiling system. The oil collection pan has three AN fittings to use for scavenging. Two of the fittings are approximately on the same level, the third is about 1/2 to 3/4 inch higher than the other two. The system ran for years with no problem using a three stage pump (one pressure and two scavenge stages). The two scavenge stages were connected at times to any two of the three AN fittings on the tank. Recently I tried an upgrade to a four stage pump...
