Need for Lorentz transformation in pre-relativity period
The discussion centers on the necessity of Lorentz transformation prior to the establishment of relativity, particularly in relation to the invariance of the speed of light across different inertial frames. It questions the role of Lorentz transformation in addressing the null result of the Michelson-Morley experiment and its connection to the invariance of Maxwell's equations. The invariance of these equations under Lorentz transformations is highlighted as a fundamental mathematical property that has been inherent since their formulation by Maxwell, despite his lack of awareness of this aspect. Without this invariance, Maxwell's equations would not retain their identity as understood in modern physics. The conversation underscores the critical link between Lorentz transformation and the foundational principles of electromagnetism.
faheemahmed6000
What was the need for Lorentz transformation in pre-relativity period?
Why was it necessary for the velocity of light to be invariant between different inertial frames and hence what was the need for Lorentz transformation when it was believed that velocity of light was constant with respect to aether. Was Lorentz transformation build in order to explain the null result of Michelson-Morley experiment?
What goes wrong if Maxwell's equations are not invariant under a transformation? What is the need for necessarily making Maxwell's equations invariant by introducing Lorentz transformation?
Did you google a bit ?
[edit] looked at your other post and found what you are doing. Hats off !
I hope my reply wasn't too flippant and you indeed hadn't found this piece of history. Found it and its companion via Lorentz
It is an intrinsic mathematical property of Maxwell's equations, that they are invariant under Lorentz transformations. This property has been contained in the equations ever since Maxwell put them in their final form with his addition to Ampere's Law, even though Maxwell himself did not know about it!
If Maxwell's equations were not invariant under Lorentz transformations, they would not be Maxwell's equations as he knew them (and as we know them).
I'm working through something and want to make sure I understand the physics. In a system with three wave components at 120° phase separation, the total energy calculation depends on how we treat them: If coherent (add amplitudes first, then square): E = (A₁ + A₂ + A₃)² = 0 If independent (square each, then add): E = A₁² + A₂² + A₃² = 3/2 = constant In three-phase electrical systems, we treat the phases as independent — total power is sum of individual powers. In light interference...
  • · Replies 35 ·
  • · Replies 32 ·
  • · Replies 33 ·
  • · Replies 34 ·
