Need help and advice with a little work
  • Thread starter Thread starter dead_devil_66
    Work
The discussion revolves around coding a boomerang simulation, focusing on the forces acting on the boomerang, including lift, drag, and torque, as well as the relationship between wind and initial velocity. The user is tasked with determining the angle between the initial velocity and the horizontal plane that allows the boomerang to return to its starting point. They have developed a system of differential equations based on Newton's second law but are uncertain about how to proceed with the calculations, particularly regarding the effects of lift and drag on the angular momentum. The user also seeks clarification on implementing the Runge-Kutta method for trajectory calculations. Overall, they express frustration with the complexity of the assignment and seek guidance from the forum.
dead_devil_66
Hi.
Im coding a little boomerang simulation. This is what my teacher gave me:
Someone throws a boomerang against the wind, with initial velocity making 45º degrees (in the vertical plane) with respect to the wind.
There are 3 forces changing the behaviour of the boomerang: the lift force, the drag force and the torq. The torq is perpendicular to the angular momentum and points in the opposite direction of the wind velocity with respect to the boomerang.
My teacher wants me to give the angle between the initial velocity and the horizontal plane that makes the boomerang return to the same place from where it was thrown.
After that, he wants me to draw the flight path of the mass center in the XY plane.
By the way, the magnitude of the wind has the following relation: Vw/g = sqrt(h)
h represents the height of the boomerang with respect to the ground.
Initial data: lift coeficient, drag coeficient, boomerang mass, gravity, air density, side angle between the boomerang and the ground, torq module, magnitude of the initial velocity of the boomerang with respect to ground (or the wind...im not really sure >.<) and the wind velocity vector with respect to the ground.
(Note: everything that has a ´ before any letter, is a vector.)
the wind vector is within the XY plane
so...this is what i have done, so far:
a differential equation system, using the 2nd Newton Law:
M * (d(´Vb/g)/dt) = M * ´g + ´D + ´S
d´r/dt = ´Vb/g
TorqRes = d´L/dt
The relative velocity relations are given by:
V´b/g = V´w/g + V´b/w
b -> boomerang
w -> wind
g -> ground
I know that the area of boomerang that is exposed to the wind depends of the angle between the angular momentum and the wind velocity with respect to the boomerang.
So:
Ad = |cos(angle(´L , ´Vw/b)| * R^2 * pi = arcos( (´L dot ´Vw/b)/(||´L|| * ||´Vw/b||) ) * R^2 * pi
Ad => drag area
R => boomerang radius
I know that the angle between the boomerang initial velocity projection in XY plane and the wind velocity is 45º degrees. So,
(Vi is the initial velocity, as you might have notice...)
´Vw/g dot 'Vib/w = (||´Vw/g|| * ||´Vib/w||) * cos 45º <=>
<=> (´Vw/g)X * (´Vib/w)X + (´Vw/g)Y * (´Vib/w)Y + (´Vw/g)Z * (´Vib/w)Z = (||´Vw/g|| * ||´Vib/w||) * cos 45º <=>
<=> Now what? *shame on me*
i guess its another system...
(´Vw/g)X * (´Vib/w)X = (||(´Vw/g)X|| * ||(´Vib/w)X ||) * cos 45º
(´Vw/g)Y * (´Vib/w)Y = (||(´Vw/g)Y|| * ||(´Vib/w)Y ||) * cos 45º
(´Vw/g)Z * (´Vib/w)Z = (||(´Vw/g)Z|| * ||(´Vib/w)Z ||) * cos 45º
Now...to calculate the torq:
I know that the torq vector is withing the plane that has the angular momentum vector as the normal vector. So, given that ´L=(Lx,Ly,Lz) then
Lx * x + Ly * y + Lz * z + d = 0 is the plane equation.
i know that the torq point in the most opposite direction of the wind with respect to the boomerang. So, torq points in the opposite direction of the projection of the wind, with respect to the boomerang. So,
´N = ´L/||´L||
´U = ´Vw/b - (´Vw/b dot ´N) * ´N
´TorqRes = -´U
So...
Now the system is something like this >.<
d´r/dt = ´Vb/g
´Vw/b - (´Vw/b dot ´(´L/||´L||)) * ('L/||´L||) = d´L/dt
M * (d(´Vb/g)/dt) = M * ´g + (1/2)*(Cd*rho*Ad*(´Vb/w)^2) + (1/2)(Cl*rho*Al*('Vb/w)^2)
d´r/dt = 'Vb/g
-1*(´Vw/b - (´Vw/b dot ´N) * ´(´L/||´L||))) = d´L/dt
Notes:
rho -> fluid density
Cd -> drag coeficient
Cl -> lifting coeficient
Al -> boomerang area exposed to the lifting force
If the angle between the boomerang and the horizontal plane is constant, then, Al is constant. Consider that to be the case.
Now, i need to divide each equation in 3 equations, each one representing each vector component. So:
In X component:
M * (d('Vb/g)X/dt) = M * ´gX + (1/2)*(Cd*rho*Ad*(´Vb/w)X^2) + (1/2)(Cl*rho*Al*(´Vb/w)X^2)
(d´r/dt)X = ('Vb/g)X
-1*((´Vw/b)X - (´Vw/b dot ´(´L/||´L||)X) * '('L/||´L||))X) = (d´L/dt)X
In this component, i think the lifting force isn't making anything...am i right? Or is it changing the angular momentum? If that is
In Y component:
M * (d(´Vb/g)Y/dt) = M * ´gY + (1/2)*(Cd*rho*Ad*(´Vb/w)X^2) + (1/2)(Cl*rho*Al*('Vb/w)Y^2)
(d'r/dt)Y = ('Vb/g)Y
-1*((´Vw/b)Y - (´Vw/b dot ´(´L/||´L||)Y) * (´L/||´L||)Y) = (d´L/dt)Y
In Z component:
M * (d(´Vb/g)Z/dt) = M * ´gZ + (1/2)*(Cd*rho*Ad*(´Vb/w)Z^2) + (1/2)(Cl*rho*Al*(´Vb/w)Z^2)
(d´r/dt)Z = (´Vb/g)Z
-1*((´Vw/b)Z - (´Vw/b dot ´N) * (´L/||´L||)Z) = (d´L/dt)Z
Does the drag have any value in this component? :|
So...the one of the objectives of this work is to find the angle between the initial velocity and the horizontal plane. I guess that angle is a variable in some Z component equation. Am i right? Damn work...there are some aspects in this work that i don't even have in my course study plan. >.<
To have the values for the trajectory, a teacher told me to use Runge Kutta 2 method. Well, that's easy to code. I guess that when i have the equations, i just need to give them as the input to the RK2 algorithm. Then, it will give me the results. Am i right?
Help needed.
Thanks in advance :')
Are you sure you meant to post this question in this section?
im not sure where to put this...sorry...can anyone help me? >.<
hello? =/
seems this is too difficult even for this forum :/
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
