Understanding Neutral Buoyancy: Formulas and Calculations Explained
  • Thread starter Thread starter ch5112
    Forces
ch5112
Hi Genius..
I have no idea where to start..please help me out with this question.
Please see the attached file, it has question and diagram..
for part (a), i know what it menas by neutral buoyant:
Neutral buoyancy is a condition in which a physical body's mass equals the mass it displaces in a surrounding medium. This offsets the force of gravity that would otherwise cause the object to . An object that has neutral buoyancy will neither sink nor rise.
but from part (b), I am not sure what formulas to use and do calculation..
please help me out in details with explantions and some solutions
Thank you
.For part (b), the formula you need to use is the equation of hydrostatic equilibrium: P = ρgh, where P is the pressure, ρ is the density of the fluid, g is the acceleration due to gravity, and h is the height of the fluid. To solve this, you will need to know the density of the fluid, which is given in the problem as 1000 kg/m³. You also need to know the acceleration due to gravity, which is 9.81 m/s². Now, you know that the object has neutral buoyancy, so the pressure at the bottom of the object, at a depth of 2 meters, is equal to the pressure at the top of the object, at a depth of 0 meters. This means that you can equate the two pressures for the equation of hydrostatic equilibrium. That is, P = ρgh. Plugging in the values from the problem, you get: 1000 kg/m³ * 9.81 m/s² * 2 m = 19620 Pa. This is the pressure at the bottom of the object. The pressure at the top of the object is the same, so it is also 19620 Pa.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
