Help Me Ace My Physics Final: Solving 12 Difficult Problems
In summary: F = m(g+a) = 2200(9.8 + 5) = 2200*14.8 = 32,560 NIn summary, Caldus is struggling with Physics and is looking for some help with a few problems on a review worksheet. The problems involve calculating velocity, distance, weight, and force using various equations and principles such as projectile motion, Newton's laws, and conservation of momentum. Caldus has been given some tips and hints to help solve the problems on their own.
Caldus
106
My final exam for Physics is tommorrow and I'm just not good with this stuff at all.
Here are some problems that I'm having trouble with on this review worksheet I was given. I don't need answers, I need to know how to do these problems. If anyone could show me how to do at least a problem or two then I would greatly appreciate it:
1. A pilot heads due north at an air speed of 380 km/h. A 112 km/h wind is blowing from the west. Calculate the velocity of the plane relative to the ground. (I just don't know how to convert from km/h to m/s.)
2. An object is shot up into the air at a 45 degree angle with a velocity of 141 m/s. Calculate the distance the object travels before striking the ground.
3. An astronaut weighs 900 N at the Earth's surface. Calculate the astronaut's weight at an altitude of 32,000 km above the Earth's surface.
4. A 5.0 g bullet leaves a gun at 1.00 x 10^3 m/s. The gun has a mass of 4.0 kg. Calculate the recoil velocity of the gun.
5. A 2.85 x 10^5 N freight car coasts along a level track at 1.2 m/s. The brakes are applied, and the car stops in a distance of 6.0 m. Calculate the average braking force.
6. What is the kinetic energy of a 15,700 N car moving at 30 km/h?
7. A 6.0 kg ball is at rest at the top of an inclined plane that is 2.5 m tall. What is the speed of the ball when it reaches the bottom of the incline?
8. A track star in the broad jump goes into the jump at 12.0 m/s and launches himself at 20.0 degrees above the horizontal. How far does he jump?
9. An object that weighs 5000 N is suspended by two cables. Cable 1 applies a horizontal force to the right of the object and has a tension T1. Cable 2 applies a force upward and to the left at an angle of 37 degrees with the horizontal and has a tension T2. Determine the magnitude of T1 and T2.
10. Determine the acceleration of a 25 kg crate that is pulled across the floor by a 275 N force applied at 35 degrees above the horizontal. The frictional force is 15 N.
11. What upward force is applied by a crane to lift a 2200 kg car at a constant velocity of 5 m/s.
12. What upward force is applied by a crane to lift a 2200 kg car at a constant upward acceleration of 5.0 m/s^2?
Again, I'm not looking for someone to do all of these, but at least a few maybe so that I may be able to figure out other problems.
Thanks.
Greetings Caldus, and welcome to PF !
How about if you’re given a few tips that help you to solve them yourself? Here are a couple of hints;
1) 1 km = 1000 meters. 1 hour = 3600 seconds. 1km/hr = 1000m/3600s.
2) Do you know how to break this down into the X and Y components?
Does that help any?
The object will undergo projectile motion. As BoulderHead has said, we need to break this down into the X and Y components.
Let u be the initial velocity (141 m/s in this case)
θ be the angle of projection (45 degrees in this case)
Take upward positive
For X component, the horizontal motion :
initial velocity, ux = u cos θ = 141 cos θ
distance traveled in time, t = utcosθ
acceleration = 0 since there is no external force acting horizontally on the object.
For Y component, we can apply Newton's laws of motion because the object is under constant acceleration, which is gravity, g.
acceleration, a= -g
initial velocity, uy = u sin θ
velocity after time t, vy = usin θ -gt
displacement, sy = ut sin θ - 0.5 gt2
When the object reaches the ground again after the projectile motion, vertical displacement, sy = 0
therefore
ut sin θ - 0.5 gt2 = 0
t = 2u sin θ / g .......(1)
Horizontal displacement
= ut cos θ .....(2)
substitute (1) in (2), you'll get the answer.
Gravitational field strength, g = GM/r^2, where r (unit : meter) is the distance between the centre of the Earth and the astromaut, which is radius of the Earth + height from the ground. M is the mass of the Earth and unit is kg.
Weight of the astronaut = mass*g
Moreover, you can find out the gravitational field strength at any altitude above the Earth by that formula, but don't forget to add the radius of the Earth to the height above the ground.
Use conservation of momentum.
[sum] mivi = [sum]mjvj
In this case, momentum before the bullet leaves the gun = 0.
Momentum after the bullet leave the gun = mgun*vgun+mbullet*vbullet
Therefore,
mgun*vgun+mbullet*vbullet=0
Since the car is lifted with constant velocity, meaning no external force is acting on it. Therefore weight of the car = force applied by the crane = mg
[sum] F = ma
Force applied by the crane - weight of the car = mass of the car * acceleration.
F - mg = ma
1. How can I improve my problem-solving skills for my physics final?
To improve your problem-solving skills for your physics final, you can practice solving various types of problems and understand the underlying concepts. You can also seek help from your teacher or peers if you are stuck on a particular problem.
2. What are some common mistakes students make when solving physics problems?
Some common mistakes students make when solving physics problems include not fully understanding the given problem, using incorrect formulas or equations, and not checking their work for errors. It is important to read the problem carefully and double-check your work to avoid these mistakes.
3. How can I approach solving difficult physics problems?
To approach solving difficult physics problems, it is important to break down the problem into smaller, more manageable parts. You can also draw diagrams or make notes to better understand the problem. Additionally, try to relate the problem to real-life situations to gain a better understanding of the concept.
4. How should I manage my time when solving 12 difficult physics problems?
To manage your time effectively when solving 12 difficult physics problems, it is important to prioritize the problems based on difficulty level and allocate more time for the harder ones. It is also helpful to set a time limit for each problem and move on to the next one if you are stuck in order to make the best use of your time.
5. What resources can I use to help me ace my physics final?
There are various resources available to help you ace your physics final, such as textbooks, online tutorials, practice problems, and study groups. You can also consult your teacher for extra help or attend review sessions. It is important to use a combination of resources to fully understand the topics and improve your problem-solving skills.
