Need help finding Volume bound by curves.
8 replies · 2K views
revolve
The region bounded by the given curves is rotated about x = 10
[tex] x=1-y^{4}, x=0[/tex]
Find the Volume V of the resulting solid by any method.
I'm using the washer method. Not sure if it is being setup properly as I'm getting the wrong answer. I will show my integration steps if the problem is setup correctly. Thanks.
[tex] \begin{alignl*}<br /> 1-y^{4}=0 \\ \\<br /> <br /> y^{4}=-1 \\ \\<br /> <br /> \Rightarrow y=\pm1 \\ \\<br /> <br /> 10^{2}-((1-y^{4}))^2 \\ \\<br /> <br /> \pi \int_{-1}^{1} (10^{2}-((1-y^{4}))^2 dy \\ \\<br /> <br /> = \frac{8936\pi}{45} \\<br /> \end{alignl*}[/tex]
Hmm can't edit my LaTex code. That integral should have Pi out front.
10 is the outer radius alright. I don't think (1-y^4) is the inner radius, though. You are rotating the inner curve around x=10 as well. Shouldn't it be larger. Check you picture again.
Should the inner radius be 1+y^4 ?
Okay, Thank you! I think I'm on the right path now. No?
[tex] <br /> \pi \int ((10^{2}) - (10-(1-y^{4}))^{2})dy<br /> [/tex]
Yeah, I must have caught that while you were posting.
I think I messed up my algebra somewhere. Could someone check over this for me? Thanks.
[tex] \pi \; \int_{-1}^{1}{\left( 100\; -\; \left( 100+10+10y^{4}+10+1+y^{4}+10y^{4}+y^{4}+y^{8} \right) \right)}dy[/tex]
[tex] \pi \; \int_{-1}^{1}{\left( -21-22y^{4}-y^{8} \right)}dy[/tex]
[tex] \pi \; \left[ -21y\; -\frac{22y^{5}}{5}-\frac{y^{9}}{9} \right]\; from\; -1\; to\; 1[/tex]
[tex] \pi \; \left[ \left( -21\; -\frac{22}{5}-\frac{1}{9}\; \right)\; -\; \left( 21+\frac{22}{5}+\frac{1}{9} \right) \right][/tex]
[tex] \pi \; \left( -42-\frac{44}{5}-\frac{2}{9} \right)\; =\; \pi \left( -\frac{1890}{45}-\frac{396}{45}-\frac{10}{45} \right)=\; \frac{1484\pi }{45}[/tex]
I'm pretty sure answer should be:
[tex] \frac{1376\pi }{45}[/tex]
