Learn How to Integrate dy/dx=4x-2y with Expert Tips - Solve D.E.
  • Thread starter Thread starter coffeebean51
    Integrating
coffeebean51
how do you integrate \frac{dy}{dx}=4x-2y.
I don't know if this is right, but this is where I'm going with this:
y'=4x-2y
y'+2y=4x
Solving homogeneous for complementary solution:
y'+2y=0
Solving auxiliary equation:
m+2=0
m=-2
Which gives
y=c_{1}e^{-2x}
y'=-2c_{1}e^{-2x}Now solving original D.E.: y'+2y=4x
-2c_{1}e^{-2x}+2(c_{1}e^{-2x})=4x
I'm lost at this step.
y'=4x-2y
y'+2y=4x
y'+2y=0
m+2=0
m=-2
Which gives
y=c_{1}e^{-2x}
y'=-2c_{1}e^{-2x}
You should be! You found y= e-2x as a solution to the equation y'+ 2y= 0. It can't possibly give 4x!
I suspect you are thinking of a looking for a solution of the form y(x)= u(x)e-2x where u is an unknown function of x. Then y'= -2ue-2x+ u' e-2x so y'+ 2y= -2ue-2x+ 2u' e-2x+ 2ue2x= 2u' e-2x= 4x. The part not involving u' cancels precisely because e-2x satisfies the equation= 0. Now u'= 4xe2x. You can use integration by parts to find u and put it back into y= u e2x to find y.
Another method, simpler here, is the "method of undetermined coefficients": Since the derivative of 4x will give a constant that will have to be cancelled, try y= Ax+ B. Then y'= A so y'+ 2y= A+ (Ax+ B)= Ax+ (A+ B)= 4x+ 0. For that to be true for all x, you must have "corresponding coefficients" equal: A= 4 and A+ B= 0.
It is a linear inseparable diff. equation, so find the integrating factor, e^(2x), multiply by the integrating factor, and solve, and you get y=2x-1 +c*e^(-2x)
