Need help proving limit does not exist
  • Thread starter Thread starter mathie_geek
    Limit
20 replies · 5K views
mathie_geek
I need to prove a limit does not exist for f(x,y) as (x,y) -> (0,0). I already tried approaching from y=mx and I got the limit 0.
f(x,y) = ((|x|^a)(|y|^b))/((|x|^c)+(|y|^d)) where a,b,c,d are positive numbers and a/c+b/d ≤
I got limit = 0 approached from y=mx.
I can't use Squeez Theorem either. How should I approach this question? Just a hint would be good. Thanks!edit: Sorry, missed a + sign in the denominator!
f(x,y) = ((|x|^a)(|y|^b))/((|x|^c)(|y|^d)) where a,b,c,d are positive numbers and a/c+b/d ≤ 1
I can't use Squeeze Theorem either. How should I approach this question? Just a hint would be good. Thanks!
Hello mathie_geek. Welcome to PF!
Edited:
[STRIKE]I assume your function really is:[/STRIKE]
I see you corrected it to be:
[itex]\displaystyle f(x,y)=\frac{|x|^a\,|y|^b}{|x|^c+|y|^d}\ .[/itex]
Thanks!
Trying to learn how to input functions :P
I missed a + so denominator is |x|^c + |y|^d
mathie_geek said:
Thanks!
Also, what is the restriction on a/c & b/d?
Is it as you said, [itex]\displaystyle \frac{a}{c}+\frac{b}{d}<1\,,[/itex]
[STRIKE]or is it[/STRIKE] [itex]\displaystyle \frac{a}{c}<1\ \text{ and }\ \frac{b}{d}<1\ ?[/itex]
Added in Edit:
Never mind, I see that it must be as originally stated.
It's (a/c)+(b/d) <= 1
can anyone help
jbunniii said:
Hint: try setting x = t^p, where p is some power, and y = t^q, where q is some other power.
I got lim y->0 ((|t|^ap)(|y|^b))/((|t|^pc)+|y|^d)) = 0
and lim x->0 ((|x|^a)(|t|^bq)/((|x|^c)+(|t|^dq)) = 0
Did I do something wrong?
Are there conditions on a, b, c, and d? If a+b is not larger than c+d you will NOT get "0" as limit for y=mx.
No, I meant that you should pick appropriate values for p and q (in terms of a, b, c, and d) which will give you a counterexample. Hint: try to choose values which will get rid of the exponents in the denominator.
This will transform the problem into a limit involving a single variable, t. Then let that variable t approach zero. By doing this, x and y will approach (0,0) along a certain curve, instead of a straight line. If you do it right, you can get a nonzero limit.
ok, I tried x = t^(d/c) and y = t^(c/d) as two different limits so I got:
lim y->0 (|t|^ad/c)(|y|^b)/((|t|^d)+(|y|^d))
lim x->0 ((|x|^a)(|t|^bc/d))/((|x|^c)+(|t|^c))
those both =0 though.
I'm sorry I'm not that good at this.
Do you mean to put both of the substitutions into one limit of t->0?
a/c <= 1-(b/d)
No, try to choose powers which will make the exponent in both terms of the denominator equal to 1.
Yes, make both substitutions at once, and then take the limit as t->0.
m_geek,
Try letting (x, y) → (0, 0) along the path [itex]\displaystyle y=x^{c/d}\ .[/itex]
That makes the denominator be fairly well behaved. I haven't checked it beyond that.
OH, I let y= t^(1/d) and x=t^(1/c)
so that lim t->0 (|t|^a/c+b/d-1)/2
and since a/c+b/d-1 <= 0,
then the limit would be 1/2 if a/c+b/d-1=0 or does not exist if a/c+b/d-1< 0.
since the two limits do not agree, limit d.n.e.
Is this correct? :D
SammyS said:
m_geek,
I tried that but I don't know why it didn't work out for me because I kept getting 0 as the limit..
Let's see your work for this, because it did work out for me & the limit is not zero.
I let ##y = x^(c/d)##
so that it simplifies to ##(|x|^ (a+(bc/d)))/2(|x|^c)##
which as x->0 limit becomes 0/2 ? I'm not sure how to take into account the inequality of a,b,c,d though
mathie_geek said:
I let ##y = x(c/d)##
so that it simplifies to ##(|x|^{a+(bc/d)}) /(2(|x|^c))##
I have fixed your Latex above, and repeat it below, so you can see the code.
[itex](|x|^{a+(bc/d)}) /(2(|x|^c))[/itex]
Now as a more readable fraction:
[itex]\displaystyle \frac{|x|^{a+(bc/d)}}{2(|x|^c)}[/itex]
Write that expression using |x| only once.
Remember, [itex]\displaystyle \frac{x^R}{x^T}=x^{R-T}\ .[/itex]
I got this after: [itex](|x|^{a+(bc/d)-c}) /{2}[/itex]
expanding the exponents I have [itex]\displaystyle \frac{acd+bc^2-c^2d}{cd}[/itex]
and given [itex]\displaystyle \frac{ad+bc-cd}{cd}<=0[/itex] which is 1/c of the exponent..
So then |x| has an exponent negative so limit d.n.e right? cause limit of 1/|x| as x->0 d.n.e
Actually, that's [itex]\displaystyle \frac{ad+bc-cd}{d}\le 0[/itex]
What if [itex]\displaystyle \frac{ad+bc-cd}{d}=0\ ?[/itex]
Now, maybe you can adjust the path so that the exponent is always zero.
Oh, I see. Since [itex]\displaystyle \frac{ad+bc-cd}{d}> \displaystyle \frac{ad+bc-cd}{cd}[/itex] then does that mean it HAS to = 0? If it's 0 then lim is 1/2
Let's go back to the exponent:
[itex]\displaystyle <br /> \frac{acd+bc^2-c^2d}{cd}=\frac{c(ad+bc-cd)}{cd}=\frac{ad+bc-cd}{d}\ .[/itex]​
I have no idea as to why you multiplied that by 1/c .
Unless you meant to say that "a,b,c,d are positive integers [STRIKE]numbers[/STRIKE]" (emphasizing integers, rather than numbers), the following inequality
[itex]\displaystyle <br /> \frac{ad+bc-cd}{d}>\frac{ad+bc-cd}{cd} \ \ \text{ is not true.}[/itex]​
The number, c, might very well be less than 1 if a, b, c, and d are not required to be integers.
All that I said was, if a/c + b/d ≤ 1, then [itex]\displaystyle \frac{ad+bc-cd}{d}\le 0[/itex].
If you choose the case of it being an equality, (choose the = sign), then the limit is defined, with said limit being 1/2.
However, that's far from being the general case for this expression.
