Need help proving some trig identities
The discussion revolves around proving two trigonometric identities. The first identity, 1 + sec²x sin²x = sec²x, was approached by substituting sec with its cosine definition and applying Pythagorean identities, leading to a successful proof. The second identity, sinx/(1-cosx) + sinx/(1+cosx) = 2cscx, required combining fractions and simplifying, ultimately confirming the identity as correct. Participants emphasized the importance of starting from basic definitions and combining terms effectively for clarity. The thread concludes with a request for verification of the solutions provided.
Confusedbrah
Proving identities is a pain! Thanks in advance, guys!
1. 1 + sec^(2)xsin^(2)x = sec^(2)x
2. sinx/1-cosx + sinx/1+cosx = 2cscx
For the first problem, this is the best I got:
1 + sec^(2)x(1-cos(2)x)
For the second problem, I added the fractions together and got:
(sinx + sinxcosx + sinx - sinxcosx) / ((1-cosx) (1-cosx)) =
(2sinx) / (1-cosx) (1+cosx) =
(2sinx) / (1-cos^(2)x) =
(2sinx) / (sin^(2)x)
Welcome to PF
For the first one, go back to basics and replace sec with its cos definition ie sec(x)=1/cos(x) and it should be apparent.
For the second one, try combining the fractions on the left and also replace csc(x) with its sin(x) definition.
Likes 1 person
jedishrfu said:
Welcome to PF
Hmmm I kinda see what you're saying. I started all over with the first one and this is what I got, can anyone check if I did it correctly? It proves to be correct, at least to me.
1 + (1/cos^(2)x)(sin^(2))x) = I then multiplied the two fractions, giving me:
1 + (sin^(2)x)/(cos^(2)x) = now I combine the fractions, giving me:
(cos^(2)x + sin^(2)x)/(cos^(2)x) = now I apply a Pythagorean identity to the numerator:
(1)/(cos^(2)x) = sec^(2)x
I am still stumped on the second one. Are you saying combine fractions from the initial equation or the one I worked on and got? Thanks
Combine the LHS of number 2. Do you see why that is a good idea?
I think I got it now. For number 2, I separated the two fractions from the left side of the initial equation and got this:
(sinx)/(1) - (sinx)/(cosx) + (sinx)/(1) +(sinx)/(cosx) = then I combined similar terms and got this:
(sinx)/(1) + (sinx)/(1) = now I flipped the fractions and got this:
(1)/(sinx) + (1)/(sinx) = (2)/(sinx) = 2cscx
Can anyone check if I did it correctly? Thanks
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
